oil pan fit #1603927
04/06/14 01:02 PM
04/06/14 01:02 PM
creekside pa
O
oddjob Offline OP
oddjob  Offline OP
O
creekside pa
I have a 1978 ramcharger 4x4 with a 360 engine. will an oil pan from a 318 fit, or do I have to use one from a 360. What's the difference?
Re: oil pan fit [Re: oddjob] #1603928
04/06/14 01:46 PM
04/06/14 01:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
318 and 360 won't interchange because of the pan end opening.
Re: oil pan fit [Re: stumpy] #1603929
04/06/14 04:26 PM
04/06/14 04:26 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
^ yup different
Re: oil pan fit [Re: 76dodgeboy] #1603930
04/06/14 05:49 PM
04/06/14 05:49 PM
Kirkland, Washington
Pacnorthcuda Offline
But that 318 pan will bolt up to a hemi! I saw them do it on Vanishing Point!
Re: oil pan fit [Re: Pacnorthcuda] #1603931
04/07/14 02:40 PM
04/07/14 02:40 PM
dogdays Offline
dogdays  Offline
I believe a Mag motor pan, either 5.2 or 5.9, will work.
R.
Re: oil pan fit [Re: dogdays] #1603932
04/08/14 05:25 PM
04/08/14 05:25 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
R.
if you use a magnum engine pan...make sure you use a magnum pan gasket...
LA 360 pan is different then LA 340/318 pan in the rear pan seal..
the Magnum 5.2 and 5.9 are the same as LA 360 in the rear pan seal..just use the right gasket.
Tony
70 AARCuda Vitamin C
