'75 D100 shortbed - Doing a BB swap with son and as part of that we're dropping the suspension using van LCA's.
Extracted UCA bushings and have offset (Raybestos) bushings to install for anticipated camber correction. The new offset bushings did not come with those funky washer/retainers you normally find on each end. Presumably will need to reuse the old ones but I notice they really don't cup the end of the bushings like they would on standard bushings.
Should I reuse them anyway or use larger washers as spacers on the end?
Also, each control arm had one bushing with an additional steel sleeve pressed over the inside end. Not really sure what purpose they serve (additional support maybe) but should be fun finding something just right diameter to press them back on the new bushings.
