help with throttle linkage #160358
12/02/08 11:09 PM
12/02/08 11:09 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
I have a 318 with a weiand 2p 180 intake and im using an edelbrock 600 cfm carb. What part or bracket do I need to run the throttle cable and kickdown to the carb?
Re: help with throttle linkage [Re: derekeh] #160359
12/03/08 02:34 PM
12/03/08 02:34 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Try one of these with the stud/nut that is on the original carb (the top bracket only; Holley also sells them). Summit
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: help with throttle linkage [Re: derekeh] #160360
12/03/08 02:41 PM
12/03/08 02:41 PM
AndyF Offline
AndyF  Offline
Mancini Racing has a bunch of different throttle brackets for Mopar engines.
Re: help with throttle linkage [Re: AndyF] #160361
12/03/08 02:47 PM
12/03/08 02:47 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
These are simple enough and work. Lokar is the brand name.
Re: help with throttle linkage [Re: Dragula] #160362
12/04/08 07:52 PM
12/04/08 07:52 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
I like that simple setup dragula . Where can I get the throttle/kickdown combo?
Re: help with throttle linkage [Re: derekeh] #160363
12/20/08 11:24 PM
12/20/08 11:24 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Id like to find a throttle/kickdown setup that will work with my 904. Where can I get both together?
