Re: Isky rockers
[Re: Adam71Charger]
#1603288
04/06/14 08:31 AM
04/06/14 08:31 AM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
I used to live down the road from Isky in Gardena...I bought a set of Isky rockers right from the counter...installed them on the same motor I have now...when I went to adjust them ball studs....more than half of them snapped off. I took em back to the counter and showed them...they admittedly said they had some bad castings and they switched out the entire set of Crane Adjustables....
This was back in 2000 though...in my defense...I haven't bought anything with the name Isky on it since that rocker set
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Isky rockers
[Re: 80fbody]
#1603290
04/06/14 08:21 PM
04/06/14 08:21 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
What I like about the blueprint and bushing job I got from RAS was they also redirect the oiling to the pushrod cup and the valve spring. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
