Re: Who has used Belzona epoxy? And...
[Re: dogdays]
#1603106
04/04/14 09:53 PM
04/04/14 09:53 PM
Posts: 20,184 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Brad I am just throwing this out there but by time the second intake was ported correctly how close would it be size wise to the first picture? Why don't you play sizing a carb base gasket to see if you could just square it up or go to a dominater flange size.
[Re: BradH]
#1603107
04/05/14 12:20 AM
04/05/14 12:20 AM
Posts: 7,506 Az
Crizila
Az
Good stuff. Expensive, but I can't think of anything better for what you want to do with it. Prep is king when you do stuff like that. Surface needs to be CLEAN and rough for best adhesion. You can even drill and tap the stuff in some non-critical applications where you can't use a helicoil or thread insert.
Fastest 300
[Re: dogdays]
#1603108
04/06/14 02:52 PM
04/06/14 02:52 PM
BradH
... They were expensive then, hate to see the prices now. ... In the '80s it cost more than $150 per kg...
I think the same amount of the #1111 is about $200 today.
Nope, not cheap. But apparently one of the few products like that available today that is alcohol resistant, and I've already had one bad experience with a different brand going soft and coming loose after exposure to E10 fuel.
[Re: pittsburghracer]
#1603109
04/06/14 03:03 PM
04/06/14 03:03 PM
BradH
I actually have one of the Hughes-modified intakes (a.k.a. "Franken-intake") that's since been reworked to use w/ my CNC-ported Victors.
The work done with their welded-up carb flange actually filled in the gap you'd see under a standard square-bore gasket laid over the spread-bore style flange. In addition, it provided a radiused transition into the tops of the runners not possible by trying to rework the spread-bore style.
When I spoke briefly w/ Dave H. months ago about whether they still offer that mod, he said it wasn't something they'd done in a long time and didn't know what the cost would be today. I remember how expensive it was when I had my intake modified... and I suspect my being able to replicate the same thing -- even using an expensive product like Belzona -- would still be a lot less than having them do it at today's price.
