Re: Thoughts on Hyd. vs. solid roller cam
[Re: drew72]
#1603087
04/04/14 10:10 PM
04/04/14 10:10 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I'm running the Comp 23-712-9 (XR286HR-10) Hydraulic roller in my 505" stroked 440, and it seems pretty tame. I used the Hughes 5319 lifters, they are only $370/set. The only lifter bore prep was running the Hughes 8319 lifter burnishing ball through the lifter bores. The engine is not as quiet as I thought it would be, but I may be hearing the roller thrust button with the stock timing chain cover? I originally was using 1.7:1 ratio rocker arms, so I used the ISKY 8005A valve springs. The Beehive springs may be better, but are more expensive too. I think if I was going to do this again, I would just use a tight lash solid roller cam with a "street" type lobe profile.
[Re: MR_P_BODY]
#1603088
04/04/14 10:13 PM
04/04/14 10:13 PM
Posts: 343 S.E.Mich
drew72
S.E.Mich
Whats your goal for performance and what kind of RPM
Figuring on 6k-6200 max. Just using stealth heads port matched, so not expecting the moon or anything
[Re: drew72]
#1603089
04/05/14 01:24 AM
04/05/14 01:24 AM
Posts: 77 British Columbia Canada
Challenger340
Port matched Stealths on a 505 are NOT going anywhere near 6-6200 rpm... FORGET IT ! You are corked well before 5500rpm with even a small 240ísh @ .050 HR profile.
Better to be a "has been" than a "never was".
[Re: drew72]
#1603091
04/05/14 02:55 AM
04/05/14 02:55 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
The term "roller" seems to blind some(guess it sounds great?right? ). A hyd roller is nothing like a solid roller and shouldn't be thought of in the same paragraph. Low RPM street builds a hyd roller may be fine,for a real build go solid flat or solid roller,I even suggest hyd flats over some of the hyd roller stuff. We are talking available MOPAR .904 lifters. Anyone have a low cost spintron I can borrow for a few days??
[Re: StealthWedge67]
#1603094
04/05/14 03:25 AM
04/05/14 03:25 AM
Posts: 2,141 junction city oregon
viperblue72
[Re: drew72]
#1603095
04/05/14 09:29 AM
04/05/14 09:29 AM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Just on the little that you have stated it seems like there is a little bit of a mis-match in your direction for the build, IMO. You have unported Stealth's (budget minded build) and considering a roller cam??? Have you gotten into the details of the cost to run a roller?
Certainly mixing it up a bit and doing it your way is cool. Hell, I run manifolds. But if you are wanting the best performance for the $ spent, I would probably CNC the heads, and get a solid FT, FWIW.
To your question. If you simply want a roller, it sounds to me like the hyd. roller would be better for you. You'll give up a little power, but it will be easier on parts, and lower maintenance.
