Late model 17" wheels #1602880
04/03/14 09:46 PM
04/03/14 09:46 PM
SW Missouri
moparmandjh Offline OP
SW Missouri
Will late model wheels work on my 1980 Ramcharger? I know the 5x5.5 bolt pattern is the same, what about the offset and fitting over the hubs?
Thanks in advance!
American soldiers in battle don't fight for what some president says on tv, they don't fight for mom, apple pie, or the American flag... they fight for one another. -Lt. General Hal Moore
Re: Late model 17" wheels [Re: moparmandjh] #1602881
04/04/14 12:38 AM
04/04/14 12:38 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
If your Ramcharger has the 5 on 5.5" bolt pattern that much is the same...however I tried to fit some 17s from a newer Ram onto my 1999 2wd 1500 that came with 16s and ran into issues with the pilot hole being different from 4wd to 2wd...they fit the back but not the front. Check the fit on your truck before you lay out the cash and mount the new tires DAMHIK
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Late model 17" wheels [Re: Polarapete] #1602882
04/04/14 12:40 AM
04/04/14 12:40 AM
SW Missouri
SW Missouri
That's what I was worried about. Thanks!
Re: Late model 17" wheels [Re: moparmandjh] #1602883
04/04/14 02:34 PM
04/04/14 02:34 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
On this style the offset is 1" different (more back spacing), I modified some wheel spacers.
I think I was being really anal about it, but had myself convinced I wanted hub centric spacers, which in my application didn't exist.
So I modified some ...backside center bore needed to be machined out, and the center hole in the wheels needed what basically amounted to a clean up, just a careful few thou.
I used 2" on the rear, and 1" on front. Now that it is on there, I wished I could have gotten 1 1/2" for the back, it would have eliminated the clearance issues with the fender lip.
It takes gasoline to interest me.
Re: Late model 17" wheels [Re: VL21] #1602884
04/04/14 02:36 PM
04/04/14 02:36 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
can't you get a half an inch milled off them?
Re: Late model 17" wheels [Re: Golden-Arm] #1602885
04/05/14 11:30 AM
04/05/14 11:30 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
I THINK the 1 1/2" are probably available, but when I was eyeballing the thing I went by that old rule, if a little is good, too much is just right.
Actually, the backspacing would be same as stock with a 1" spacer, and I was having some inside rubbing with 255/70/15 on stock rims, so thought the extra inch would be fine.
It is the extra width of the rim that makes the diff.
I did the rear first, and tried the 2" on the front to check clearance ... better with the stock offset, wider rim and a 1" spacer.
Thought about having the spacers shaved, but their design won't allow it ... the seat for the inner (attaching nuts) is too close to the backside, and on the outer the studs are too close to the front surface.
It was very close to clearing, and with a smaller tire (these are 275/60/17) I think it would clear, and if it wasn't lowered it would be ok, and possibly a little shift of the bed/frame relationship would make it work ...
and if pigs had wings ...
