Fan Clutch for 71 Cuda with 440 #1602406
04/02/14 10:40 PM
04/02/14 10:40 PM
Postville, IA
CudaDave7071 Offline OP
Postville, IA
Any fan clutch recommendations for a 71 cuda with 440?
Re: Fan Clutch for 71 Cuda with 440 [Re: CudaDave7071] #1602407
04/02/14 10:51 PM
04/02/14 10:51 PM
Georgia
Steve Bryant Offline
Georgia
For my 440 in a 70 Cuda, I opted for the Hayden 2765 from a local parts store for about $40. It bolted directly to my Mopar fan.
Re: Fan Clutch for 71 Cuda with 440 [Re: Steve Bryant] #1602408
04/02/14 11:38 PM
04/02/14 11:38 PM
IN
ahy Offline
ahy  Offline
IN
As posted above, recommended Hayden clutch based on make/model/year/cooling option. I believe there are typically two Hayden clutches. Standard and heavy duty. It needs to be matched to the fan. 5 or maybe 6 blade fans take "standard" and 7 blade takes "heavy duty". NAPA (and others) sell Hayden. AZ often sells "something else". Suggest you stick with Hayden,
Re: Fan Clutch for 71 Cuda with 440 [Re: Steve Bryant] #1602409
04/03/14 10:03 PM
04/03/14 10:03 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The drawback of the Hayden is its slotted hub since it designed as a universal..
If one want the closed Mopar hub type, check the on-line auctions for an FC28....
These were supplied by TRW to Mopar and are still around.
Just my $0.05...
