Chrysler 20" factory steel Rims #1602193
04/02/14 03:52 PM
04/02/14 03:52 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Where can I find some 20x8" steelies, 5x5.5" bolt pattern pattern? I've only been able to find some 18" versions online that were pulled from a durango. I really want a set for my truck that I can couple with the Dodge center caps that I already have.
Any help is appreciated. Thanks.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Chrysler 20" factory steel Rims [Re: roe] #1602194
04/02/14 08:17 PM
04/02/14 08:17 PM
Kansas
cascius Offline
cascius  Offline
Kansas
Re: Chrysler 20" factory steel Rims [Re: cascius] #1602195
04/03/14 01:41 AM
04/03/14 01:41 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Thanks but I tried them already. They are out and dont know if they are getting anymore. Same case with the other sites I found. And I called a dealer just to see...their parts department said they didn't think that Dodges came with a 20" steel wheel. I'll try LKQ tomorrow, but after that I dont know where else to look. Ebay, Craigslist, and Commercial retails have all been dead ends.
roe
Re: Chrysler 20" factory steel Rims [Re: roe] #1602196
04/03/14 01:47 AM
04/03/14 01:47 AM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
The older trucks came with a 20" spare. My new one has a 17" space saver type spare.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: Chrysler 20" factory steel Rims [Re: gregsrt] #1602197
04/03/14 02:08 AM
04/03/14 02:08 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
How wide is the spare? Maybe I can track down 4 of those? There's not a safety issue with that is it? But some of the trucks actually came with a full set of steel wheels, either 8 or 9 inches wide. Those are the ones i want. Unless 4 of those spares will work.
Re: Chrysler 20" factory steel Rims [Re: roe] #1602198
04/03/14 05:05 AM
04/03/14 05:05 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
2002 to 2008 Ram 1500s with the factory alloy 20" wheel package came with 20" steel spares with the same 275 55 20 tire as the 4 on the truck. These wheels are plenty beefy. The OEMs are not going to make a flimsy spare for a truck.
My 2006 Ram 1500 4x4 had 20s and a 20" spare. My 2007 was originally equipped with 17s so the spare was also a 17" size.
Re: Chrysler 20" factory steel Rims [Re: Kern Dog] #1602199
04/03/14 01:20 PM
04/03/14 01:20 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Thanks for the info. I'm gonna hit the j/y today to see what I can come up with.
Re: Chrysler 20" factory steel Rims [Re: roe] #1602200
04/03/14 02:34 PM
04/03/14 02:34 PM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
There wasn't a 20" STEEL wheel option from the factory. All factory 20" wheels, besides spares, were aluminum. If you have seen trucks with 4 steel wheels someone put together a set of 20" spare wheels. FWIW a 20" steel wheel with tire weighs about 90 lbs.
Re: Chrysler 20" factory steel Rims [Re: 73MagDuster] #1602201
04/03/14 02:58 PM
04/03/14 02:58 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Ok, maybe that's why the parts guy at the dealer couldn't find it. If I can't find four of the 20" steelies, then I'll be happy with the 18" wheels.
Re: Chrysler 20" factory steel Rims [Re: roe] #1602202
04/03/14 03:24 PM
04/03/14 03:24 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Something you might think about before you spend much to put taller wheels on there. Taller wheels will give the effect of dropping your gearing numerically. For example going from a 2257515 to a 2756020 would be a 85.74 percent decrease making a set of 3.23 gears feel like 2.77. I saw on your other thread that you're keeping your 318 basically stock so there isn't a lot of torque there to start with... I guess you could change your gears? Just something to think about.
Re: Chrysler 20" factory steel Rims [Re: Jwilli500] #1602203
04/03/14 03:41 PM
04/03/14 03:41 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Yeah, I'm going to try and minimize that issue as much a possible. Kind of like I did with my car, the rim will be bigger but I will have a tire with a shorter side wall so that the overall rim/tire height doesn't change much. I love the look of steelies on the truck, but want something bigger than the stock size rim.
Re: Chrysler 20" factory steel Rims [Re: roe] #1602204
04/04/14 04:24 AM
04/04/14 04:24 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Its Simple and Called Upsizing. Only need to find a tire with the same diameter as you ran with the smaller rims. Cant get any simpler.
Re: Chrysler 20" factory steel Rims [Re: 76dodgeboy] #1602205
04/04/14 04:27 AM
04/04/14 04:27 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
20" Factory Spares. What size Tire are you currently running?
Re: Chrysler 20" factory steel Rims [Re: 76dodgeboy] #1602206
04/04/14 11:58 PM
04/04/14 11:58 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
The truck came with 225/75/15's. Fronts are new, but I have to put two on the rear. I really want some of those 20" steelies that you have. But every where I look is a dead end. None of the salvage yards have any, and the online retailers are out of stock. Ebay and craigslist are deadends too. I'd settle for some 18's but those have been just as hard to find. Where did you find yours? And did you have to use spacers?
roe
Re: Chrysler 20" factory steel Rims [Re: roe] #1602207
04/06/14 03:42 AM
04/06/14 03:42 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Not my truck. Kid on Facebook.
