RPM at the stripe?? #1602167
04/02/14 03:35 PM
04/02/14 03:35 PM
Great Neck,LI,new york
hemi-itis Offline OP
I'm going over the finish line at 7300 and would like to see it around 66-6700 rpm.Could this be done by going from a 31 inch tall tire to a 33 inch tall tire??
Would also like to loosen the stall but that would increase the RPM at the stripe.
Now have a Dana with 4:10 & 31 inch tall tire. Peak Tq is around 5000 RPM and HP is 6200
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: RPM at the stripe?? [Re: hemi-itis] #1602168
04/02/14 04:23 PM
04/02/14 04:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Watcha worried bout, that thing should be happy there..........
Re: RPM at the stripe?? [Re: hemi-itis] #1602169
04/02/14 04:35 PM
04/02/14 04:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Figure the percentage of change in the tire dia..
then use that on the rpm
Re: RPM at the stripe?? [Re: MR_P_BODY] #1602170
04/02/14 05:14 PM
04/02/14 05:14 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: RPM at the stripe?? [Re: hemi-itis] #1602171
04/02/14 05:20 PM
04/02/14 05:20 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
(31/33)*7300 = 6857
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: RPM at the stripe?? [Re: oldiron] #1602172
04/02/14 05:22 PM
04/02/14 05:22 PM
I think I see a set of 10.5w X 33 in my future
OR,,,would a set of 3:73's with a looser converter be better???
Re: RPM at the stripe?? [Re: hemi-itis] #1602173
04/02/14 07:27 PM
04/02/14 07:27 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Because of tire clearance, I was looking at dropping down to a 4.30 or 4.10 gear. I'm going thru the traps at close to 6500 with 4.56 and a 29" tall tire. My concern is what affect this would have on my short times. Remember, I've got a heavy stick car. Don''t mean to hi-jack this post. Just thinking out loud on the web.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: RPM at the stripe?? [Re: 68LAR] #1602174
04/02/14 07:39 PM
04/02/14 07:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your gonna loose torque due to ratio... but with a stick
you can jack up the revs... will you see the change...
maybe not(on the torque) but your revs will drop
Re: RPM at the stripe?? [Re: 68LAR] #1602175
04/02/14 08:18 PM
04/02/14 08:18 PM
NOT a hi-jack,we have a similar situation.We both need to lower the RPM at the stripe
Re: RPM at the stripe?? [Re: hemi-itis] #1602176
04/02/14 10:07 PM
04/02/14 10:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Al, that must be a inefficient converter. I go through at 6900 with 4.10/10.5x31W/147 mph. Flash stall is 5700 rpm
Doug
Re: RPM at the stripe?? [Re: dvw] #1602177
04/02/14 10:27 PM
04/02/14 10:27 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I'm no expert.... but I was thinking the same thing dvw brought up. I wasn't making a ton of hp with my Mirada (high 9s), but with a 29.5 slick and 4.10 gear I was trapping in the 6200-6400 range.
Re: RPM at the stripe?? [Re: J_BODY] #1602178
04/02/14 10:43 PM
04/02/14 10:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m crossing the line at around 7200+ w/an 8" 5000+ vert and a 29" tire w/4.11`s..............
Re: RPM at the stripe?? [Re: Thumperdart] #1602179
04/03/14 12:21 AM
04/03/14 12:21 AM
I'm pulling the trans out this weekend Something ain't right This converter is 1 year old
Re: RPM at the stripe?? [Re: hemi-itis] #1602180
04/03/14 01:00 AM
04/03/14 01:00 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Check the stator, should lockup spinning one way & freewheel the other way. Easy check.
Re: RPM at the stripe?? [Re: rickraw] #1602181
04/03/14 01:35 AM
04/03/14 01:35 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I would say it all depends what mph you'r going thru the traps, to many variables to compare with different cars. What is the mph? My engine was turning 7000 but drive shaft was 5600 -a lot of slippage, still went 125 mph in eigth. Sent vert back two more times to tighten up, check that first.
Re: RPM at the stripe?? [Re: cudaman1969] #1602182
04/03/14 07:51 AM
04/03/14 07:51 AM
pa
572charger Offline
572charger  Offline
pa
i,m with doug check the convertor , ive got 4.30 gear 31.50 tall et streets and i shift at 6800 go thu traps at 7000 on a good pass with good air runnin 9.60s -9.70s ati convertor slip is only 8% it pulls like a frieght train in high gear 142mph !!! 3900lbs ,
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: RPM at the stripe?? [Re: hemi-itis] #1602183
04/03/14 08:18 AM
04/03/14 08:18 AM
ill
dennismopar73 Offline
ill
WOW! That's a ton rpms if that's correct wit 410 gear !
I think the vert you got is in need of repairs
Re: RPM at the stripe?? [Re: dvw] #1602184
04/03/14 08:59 AM
04/03/14 08:59 AM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
Doug
Exactly. Al sometimes the weight of the car and the gear have opposite effects. I thought you bought a racepak, and if you hook it up you can see converter slippage at the stripe. Will tell you facts. With that said, I would try a 4.30 and the car will tell you the answer...
SS/DA 1924
Re: RPM at the stripe?? [Re: SSDAcuda] #1602185
04/03/14 11:00 AM
04/03/14 11:00 AM
Doug
Almost finished installing the Racepak,that was one of my winter upgrades.Still have a week or so before I get into the chassis shop for those upgrades.Car won't make a pass until I get this stuff squared away
Re: RPM at the stripe?? [Re: hemi-itis] #1602186
04/03/14 02:09 PM
04/03/14 02:09 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
Yea I agree on converter. We are 29.5 tires with a 4.56 and go through at 7200..
Casey
