Rear window gasket. #1601816
04/01/14 06:15 PM
04/01/14 06:15 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Does anyone know a source for a rubber gasket (Seal) for a rear sliding window? I bought a gasket from one of the venders that was supposed to work with a rear sliding window, but there is no-way it's going to work. The rear slider frame is too wide to fit into the gasket. The gasket I have is one that does not accept a lock strip.
Thanks, Josh-
Re: Rear window gasket. [Re: jstollfu] #1601817
04/01/14 09:34 PM
04/01/14 09:34 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
Not sure if the sliding rear window weather stripping is made anymore for the 72-93 D/W series trucks. I'm using an original out of a 89 truck which the weather striping used there is really thick, but still soft enough to reuse, but all the repos I see are for the solid back glass which the weather stripping there is real flush smooth type fit, (my back glass seal sticks out toward the back for the thick channel in the slider) might try these places they might or might not have them
www.dodgeconnection.com
www.bradsnosmopar.com
www.autobodyspecialt.com
www.jimsautoparts.com
www.ebay.com
If you want I can take a pic later of the back glass that im using to show what the weather stripping looks like
Re: Rear window gasket. [Re: 98RAM1500] #1601818
04/01/14 10:30 PM
04/01/14 10:30 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
heres some pics of the slider seal that (im using I got another slider that im using this one was busted when I bought the truck)
Re: Rear window gasket. [Re: 98RAM1500] #1601819
04/01/14 10:30 PM
04/01/14 10:30 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
another closer shot
Re: Rear window gasket. [Re: 98RAM1500] #1601820
04/02/14 11:28 AM
04/02/14 11:28 AM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Thanks for the pictures. The weather strip in your photos is very different from the weather strip I picked up from one the vendors on your list. I noticed on the ABS site, they state that the weather strip will work with aftermarket rear sliders, but not factory rear sliders. I beleive mine is a factory one, it has the pentastar in the corner of the glass. Anyone else care to chime in?? Josh-
Re: Rear window gasket. [Re: jstollfu] #1601821
04/02/14 06:38 PM
04/02/14 06:38 PM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
This is who I used for all my weather-stripping. http://precisionrestorationparts.com/
Re: Rear window gasket. [Re: 77ProStreet] #1601822
04/02/14 07:01 PM
04/02/14 07:01 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Ok. so after a little research. The mopar weather strip part number for the factory rear sliding window is 3494598. Of course this part number is no longer available. The weather strip for the flat glass and the aftermarket rear sliding windows will not work with a factory rear sliding window.
I found one guy that swears the 92-96 Ford F150 used the same rear glass as the 72-93 dodge trucks. The difference being the Ford has a thicker glass.. No idea, can neither confirm or deney that claim.
The one ebay listing for the 3494598 weather strip I found was for a item that had already sold, with a selling price of $240. I'm not paying that much for weather strip.. I'll go back to the flat glass.. Crazy that no one makes a reproduction weatherstrip for the factory rear sliding window on the 72-93 trucks. 19 years of production, still a few out there.. Josh-
Re: Rear window gasket. [Re: jstollfu] #1601823
04/02/14 09:24 PM
04/02/14 09:24 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
found this one if they still have it
they have a list of nos weatherstripping for the trucks & vans you'll have to scroll down alittle to find the part number, but its there I think it said $180.00
http://www.nosmopar.com/query.asp?section=WSTRIP&year=0&make=Dodge+Truck
Re: Rear window gasket. [Re: 98RAM1500] #1601824
04/03/14 11:03 AM
04/03/14 11:03 AM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Thanks for that listing. Still, $180 for a peice of weather strip is a little more than I'm willing to spend. I'll keep looking maybe something will turn up. For now I guess I put the flat glass back in.
Re: Rear window gasket. [Re: jstollfu] #1601825
04/03/14 04:08 PM
04/03/14 04:08 PM
Dearborn, Michigan
jstollfu Offline OP
jstollfu  Offline OP
Dearborn, Michigan
Ok, out of extreme curiosity I called that place in the above link. They don't have the weatherstrip however they had located one and that's why it's listed on their web site... They sourced it through AMS obsolete. Yea, and good ole AMS wants $370.00 for a NOS weather strip.. Josh-
Re: Rear window gasket. [Re: jstollfu] #1601826
04/03/14 07:22 PM
04/03/14 07:22 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
WOW They are nuts maybe if our D & W series trucks were bringing 40K or more then that might be feasible.
Re: Rear window gasket. [Re: 98RAM1500] #1601827
04/05/14 03:00 AM
04/05/14 03:00 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
I think i have a used window with gasket. Will look tomorrow and let you know tomorrow night or sunday.
