Firewall epoxy ( Amerlock 400)
#1601763
04/01/14 03:51 PM
04/01/14 03:51 PM
Posts: 1,418 Mcallen, TX
SB449VALIANT
Mcallen, TX
I am making progress on my 65 valiant, i put a new firewall and i decide to lay a nice Amerlock 400 coat, you guys think i shoud go to bare matel, like using some type of paint striper perhaps do a little sandblasting? or just or just break the paint and smoth it out with sand paper? This is just a drag race car not a show car, the epoxy iam using may not be the best option out there, but is a free option... Thanks, Gilbert.
Re: Firewall epoxy ( Amerlock 400)
[Re: MR_P_BODY]
#1601767
04/01/14 05:23 PM
04/01/14 05:23 PM
SB449VALIANT
Mcallen, TX
Thanks for the help.. I'll throw on some self etching primer, then throw on some of this coats! ...i still need to do more metal sanding..... Gilbert.
[Re: SB449VALIANT]
#1601769
04/01/14 05:27 PM
04/01/14 05:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Gilbert.
Yeah once you get your metal ready put some self etch on it then use your high build primer
[Re: dogdays]
#1601770
04/01/14 05:32 PM
04/01/14 05:32 PM
SB449VALIANT
Mcallen, TX
Do a web search to find the product data sheet. Says it's self-priming over most surfaces and adheres to tight rust.
See for yourself, I'd be tempted to just shoot it.
That brand of paint is high quality, in general. We use it in industrial settings.
R.
You're right on that, and it really seeps into the pores of the metal,btw The epoxy smell is a knockout......
[Re: SB449VALIANT]
#1601771
04/01/14 06:08 PM
04/01/14 06:08 PM
MR_P_BODY
R.
If it is a self etch just shoot that
[Re: MR_P_BODY]
#1601772
04/01/14 06:27 PM
04/01/14 06:27 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Epoxy primer is the better option, IMO. It seals the metal from moisture, and is the ultimate sealer coat to block the existing paint from reacting with the new paint.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1601773
04/01/14 06:33 PM
04/01/14 06:33 PM
MR_P_BODY
I always use a sealer after all the work is done (bondo and primer) before spraying the color
[Re: dvw]
#1601776
04/01/14 08:16 PM
04/01/14 08:16 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Read the sheet. I was just painting some epoxy over bare metal, thought an etching primer would help. The epoxy adhered to the primer more than the primer to the metal...peeled off in big flakes...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: SB449VALIANT]
#1601779
04/03/14 03:31 PM
04/03/14 03:31 PM
Posts: 8,299 fredericksburg,va
cudaman1969
fredericksburg,va
I'll throw on some self etching primer, then throw on some of this coats! ...i still need to do more metal sanding.... Gilbert.
Where did you buy this product?
