Aerohead heads?
#1601695
04/01/14 11:25 AM
04/01/14 11:25 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Has anyone bought heads from them? $600 seems like an awful good price for a set of 906/452's with a valve job, bronze guides, new valves, etc. I know what's coming next. Just buy a set of Edelbrock heads, Source heads, etc. Out of the budget. Can't swing it. Just curious if anyone has experience, good or bad, with these heads. Thanks.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: Aerohead heads?
[Re: OhioMopar]
#1601698
04/01/14 01:47 PM
04/01/14 01:47 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I bought a set of the mildly ported Aerohead 452s that had new SS 2.14x1.81 valves and good springs for the 440 in my '64 Polara. I had no complaints at all and thought it was a good investment Of course, I did not do a back to back test against the PAW built stock 346s with 2.08x1.74 valves that I swapped, so I have no idea if it really made any difference at all I still think, they would be fine for a mild build. If you spend more, you have a right to expect more, but you will spend a lot to get a little
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: Aerohead heads?
[Re: OhioMopar]
#1601700
04/02/14 01:42 AM
04/02/14 01:42 AM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
You can buy a bare set of aluminum heads for $800. Put in 2.14-1.81 valves and light springs with a valve job, and you have less weight, and a better set of heads for around $1200 JMO
Re: Aerohead heads?
[Re: camastomcat]
#1601702
04/02/14 08:48 AM
04/02/14 08:48 AM
OhioMopar
Mt.Gilead, Ohio
Sounds good. Also sounds out of my price range. I don't think the car will stick around long enough for me to change heads. Thanks for all the replies.
Re: Aerohead heads?
[Re: camastomcat]
#1601704
04/03/14 12:58 PM
04/03/14 12:58 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
Where can you get a bare set of aluminum heads for $800?
