Misfire/popping at Idle #1601572
03/31/14 10:55 PM
03/31/14 10:55 PM
River Falls, WI
urdustd Offline OP
urdustd  Offline OP
River Falls, WI
I have a 360 I built a few years ago for my 74 Duster 360. It has an older Hughes/Engle cam HE2430, newer style MP adj mechanical advance distributor and Edelbrock heads, intake and carb. It has served me well, but probably doesn't have much more than 10K miles total on it. Just an occasional back-n-forth to work and weekend cruiser. I recently started misfiring at idle. It seems pretty good above 1500-2000 rpm, although it might be missing occasionally there too. The misfires is getting worse with time. I have concentrated on the ignition system as I figured it was a plug, wire, cap, or phasing issue. I had the engine out a while ago replacing steering box, headers, torque converter, and an oil pan leak. When I put it back together a buddy talked me into re-lubing the cam with cam lube as it was out for quite some time. It was right after this the misfire started and as I said it has continually gotten worse.
I changed, plugs, cap, wires as I went to RobbMC's cap adapter I bought from him a few years back. In addition I changed from an older orange box to a factory style and my Blaster 2 coil to an Echlen factory replacement coil. I also check cam phasing, which was off, and adjusted it by modifying the cap adapter to line the reluctor, rotor and #1 spark plug terminal on the cap. I haven't changed the pickup coil which is still an option I guess. There appears to be no vacuum leaks, the plugs are a little dark, but not bad. I went through the carb and thoroughly cleaned it. I also took a close look at all the harness under the hood (it was replaced with a Year1 harness a few years ago) and dash to make sure there are good connections, etc. It still pulls hard when got on and revs freely.
I'm stumped and am worried that putting the cam lube on wasn't such a good idea. Thinking I might have lost a lobe on the camshaft. It makes no funny noises, internally.
Does anyone have any ideas? I'm open to suggestions. I will probably try the pickup coil this weekend and probably pull the valve covers to see if there are any issues with the adjusters and rockers (Crane Golds). That might lead me to a cam issue.
Thanks in advance for anyone's help!
Re: Misfire/popping at Idle [Re: urdustd] #1601573
03/31/14 11:16 PM
03/31/14 11:16 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
No water in the fuel?
Re: Misfire/popping at Idle [Re: urdustd] #1601574
03/31/14 11:16 PM
03/31/14 11:16 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Could it be a timing chain issue? not sure a sloppy chain would cause a backfire, but it came to mind.
Re: Misfire/popping at Idle [Re: urdustd] #1601575
03/31/14 11:23 PM
03/31/14 11:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It sounds like a weak coil.. if the voltage is up on
it then it works better... I know you said you changed
it but we all know a new part doesnt mean its right
or it could still be the wires
Re: Misfire/popping at Idle [Re: urdustd] #1601576
03/31/14 11:30 PM
03/31/14 11:30 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Do a leak-down test.
Re: Misfire/popping at Idle [Re: urdustd] #1601577
04/01/14 12:00 AM
04/01/14 12:00 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not that it`s your problem but I just got a 64 Scout 4-cyl running and did the pertronics upgrade from points and it started out runnin ok but then was poppin and spittin so I checked the alt. and it`s not charging. Too many variables but check everything out.............you`ll find it and sometimes it`s simple and other times, well you know...........
Re: Misfire/popping at Idle [Re: rickraw] #1601578
04/01/14 12:01 AM
04/01/14 12:01 AM
Az
Crizila Offline
Crizila  Offline
Az
or compression test. Gotta start somewhere and a good place is always the mechanicals. Another good place to start is with a vacuum gauge. www.secondchancegarage.com has a great how to use / read a vacuum gauge section.
Fastest 300
Re: Misfire/popping at Idle [Re: Crizila] #1601579
04/01/14 03:27 AM
04/01/14 03:27 AM
River Falls, WI
urdustd Offline OP
urdustd  Offline OP
River Falls, WI
To answer a few questions.
Water in fuel - I don't think so. I always run the piss they call 91 octane out west here. But when I started to have this issue I put 10 gallons of 100 octane no lead with no change. I also added a can of Sea Foam. So probably unlikely, but I could pump the tank empty and put fresh fuel in.
Timing chain slop - I'm sure there is some as I didn't put a tensioner on it, but I used a Cloyes roller chain. I was thinking this might be why it was so out of phase. Hard to say, but there doesn't seem to be a lot of slop when turned by hand a few degrees each direction.
Coil - easy change. Might be able to borrow one to try.
Leak down/compression check- I don't have the tools for a leak down test, but I do have a compression gauge. That would be pretty easy and not a bad test to at least start with.
I think I will still pull the valve covers and change the pickup coil since I have a new one in the garage.
If anyone else has ideas I'm all ears!
Here is a video of marginal quality that I took some time ago when this started. You can hear it at idle but not when revved.
Video link
Re: Misfire/popping at Idle [Re: urdustd] #1601580
04/01/14 03:36 AM
04/01/14 03:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Go ahead and change the PU coil but normally thats
a temp thing... it'll be working then quit then when
it cools it'll work again..but try it
Re: Misfire/popping at Idle [Re: urdustd] #1601581
04/01/14 08:05 AM
04/01/14 08:05 AM
Truckville, the capital of NY
85_Ram_4speed Offline
I know when mine started popping at idle, I found a couple of holes that were way down on compression---not dead, but about 25-30% lower.
Also check the header gaskets too to see if one might not be sealing properly and sucking air in around it.
Outcast Dodge guy.
Re: Misfire/popping at Idle [Re: MR_P_BODY] #1601582
04/01/14 08:05 AM
04/01/14 08:05 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Im curious how did you relube the cam ?
Check for flat lobe slope in a rocker arm .
Plug wires moisture in wires from sitting .
Change spark plugs .
Few things that came to mind .
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: Misfire/popping at Idle [Re: urdustd] #1601583
04/01/14 10:06 AM
04/01/14 10:06 AM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
Hi Jim. If you are running hydraulic cam, maybe check for a pumped up/stuck lifter. i had that issue, seemed to drive well, but idle would miss a bit. Also the exhaust made a pfft pfft kind of sound.
Good luck. keep us updated.
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: Misfire/popping at Idle [Re: 73swinger] #1601584
04/01/14 10:32 AM
04/01/14 10:32 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Squeeze the PCV hose tight to see if the idle improves.
Could be something as simple as a worn PCV (valve).
Re: Misfire/popping at Idle [Re: BigBlockMopar] #1601585
04/01/14 12:37 PM
04/01/14 12:37 PM
River Falls, WI
urdustd Offline OP
urdustd  Offline OP
River Falls, WI
The compression test should give me an indication of the health of each cylinder.
Hey Chris - Lifter pump up is a possibility as it is a hydraulic, though I don't think it pops thru the exhaust. It's more of a rattle, like spark jump, under the hood.
Leaky header gasket - I guess that's feasible. Wouldn't the cylinder it leaks on lean out a bunch and whiten the plug? Just thinking...
PCV - Hmmm, never thought of that. At least it's easy to check.
Thumper - that low output of the alternator has me thinking too. I'll have to look into the that one.
I have a Holley Annihilator Ignition box that I can wire in too. This might bypass some of the issues or cause them to really stand out. It might take a bit to wire it in, but in the long run I want to get away from the problems associated with the MP ignition modules and ballast resistors.
Thanks again guys. This thing has me pulling my hair out and I really don't have that much to spare!
Maybe a quick video from under the hood would help out. I'll see what I can come up with.
BTW - I re-lubed the cam with break in lube while the intake was off, by brushing it on through the drain back holes in the valley. Just on the lobes, nothing on the lifters
Re: Misfire/popping at Idle [Re: urdustd] #1601586
04/01/14 02:51 PM
04/01/14 02:51 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Lash too tight / sticking lifter, burnt exhaust valve, 5/7 plug wires misarranged on cap, too lean, too much timing are a few of the things over the years I've encountered that lead to a misfire/pop out of the carb.
Re: Misfire/popping at Idle [Re: urdustd] #1601587
04/01/14 02:57 PM
04/01/14 02:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If its truely a miss then the exhaust really wouldnt
do it BUT if its a popping sound then yes it can be
the header loose.. so make sure what you have
Re: Misfire/popping at Idle [Re: urdustd] #1601588
04/01/14 03:28 PM
04/01/14 03:28 PM
Az
Crizila Offline
Crizila  Offline
Az
Lots of good suggestions on this thread. Don't hopscotch. Take your trouble shooting one step at a time and try and start with the easiest stuff first. Often you will find that it is NOT the worst case scenario ( dead hole, flat cam, etc.) If your problem started right after you changed something, that is usually the first place to look. If nothing shows up and you have no clues, start with the mechanicals as they are often visual checks and easy to do. All good?, move over to the fuel stuff as it is usually the next easiest to trouble shoot. Lastly, electrical, as much of it is non-visual and some of it is non-testable. With a good trouble shooting procedure ( leaving nothing out ) you will find the problem.
Fastest 300
Re: Misfire/popping at Idle [Re: Crizila] #1601589
04/01/14 03:48 PM
04/01/14 03:48 PM
River Falls, WI
urdustd Offline OP
urdustd  Offline OP
River Falls, WI
That is the plan and I do appreciate the input as somethings you just flat overlook as you get more frustrated.
I guess I want to reiterate. The condition appears to me as spark knock and that is why I went straight to the ignition system. As the rpm's climb the condition is much less noticeable (or disappears) and lead me to the phasing, timing, advance, and general ignition components.
I will put a list together from easiest to hardest and work my way through it. I'm sure I'll find it, just hoping it is not too bad as I have enough other junk I own to work on!
Re: Misfire/popping at Idle [Re: urdustd] #1601590
04/01/14 04:07 PM
04/01/14 04:07 PM
Az
Crizila Offline
Crizila  Offline
Az
I hear that last part.
Fastest 300
Re: Misfire/popping at Idle [Re: Crizila] #1601591
04/01/14 07:54 PM
04/01/14 07:54 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Check the lobes on your camshaft,I don't think it will be flat but wore bad.That will cause one to pop at idle but sound more clear off idle and it does not have to be wore all that bad.If you have roller lifters you may find the problem when checking the camshaft.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
