Page 2 of 3 1 2 3
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1601306
04/01/14 07:49 PM
04/01/14 07:49 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Thanks guys! Like I said, it's been around a lot longer than me!
Here is a picture from before it was painted. That is me standing beside it haha. I've grown a wee bit since then.
-Kenny
Kenny, are you sure you have? Oh and by the way I did end up picking up a set of ported W2's for my 408 set up. The only problem is I am not sure I'm ever going to use it now.
Back in the swing of things at Painless again! Great to be back!
Re: Joss Engines 542ci Low Deck Build Thread [Re: gregsdart] #1601307
04/01/14 07:51 PM
04/01/14 07:51 PM
Alberta Canada
StrokerAspen Offline OP
Alberta Canada
Did the 4.56 stroke have to use a 2.2 or 2.1 rod bearing? What was the Compression height of the piston?
The 4.56" stroke we had a 2.2 rod bearing, using a rod length of 6.635". The CD of the the piston was 1.120"
The 4.775" stroke engines that we have done using a 440 block, we used a 2.1" rod bearing. This was with a 7" rod length.
Those were steel rodded engines
This 542ci. that we are posting this build of is using a GRP 6.600" rod, with a 2.2" rod bearing. The CD on the piston is 1.120"
Thanks!
-Kenny
Re: Joss Engines 542ci Low Deck Build Thread [Re: BJS racing] #1601308
04/01/14 07:55 PM
04/01/14 07:55 PM
Alberta Canada
Alberta Canada
Haha, just a little bit. "Back when I was knee high to a grass hopper!"
-Kenny
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1601309
04/01/14 08:02 PM
04/01/14 08:02 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
And I thought my family were the only oddballs that have a 62 Plymouth and a Volare. I love it.
Doug
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1601310
04/01/14 11:07 PM
04/01/14 11:07 PM
NC
440Jim Offline
440Jim  Offline
NC
The largest stroke we have run in a stock block, which was in a 440, was a 4.775" billet. We have run a 4.5625" in a 400 block. I am quite confident this combo will work well.
I am sure you can get it to fit. Block clearancing will be needed, the piston will be short, but not unheard of. And the crank counterweights will need to be reduced to somewhere near 7.1" dia, but again that is not unheard of with the bobweight you will have (low). It is just pushing some typical combo dimensions. A good piston design for the small amount of skirt and how far it will be pulled down the cylinder should be considered.
You might want to consider a thick head gasket to get the piston to head clearance for the aluminum rods. Ask the Al rod guys for the clearance number.
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1601311
04/02/14 01:01 AM
04/02/14 01:01 AM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
Thanks!
-Kenny
Did your 4.56 stroke engine have the piston sticking out of the hole?
Re: Joss Engines 542ci Low Deck Build Thread [Re: hemiiroc] #1601312
04/02/14 01:54 AM
04/02/14 01:54 AM
Alberta Canada
Alberta Canada
Doug
Haha, yeah, my uncle has a 62 dart, and my daily driver is a Volare wagon!
Thanks for the heads up but I should probably tell you, this isn't our first aluminum rodded engine. We have our clearances we like to run, and they do work well. This is one of 3 aluminum rodded engines coming together in the shop right now. One is a small block dodge, the other is a small block Olds. I guess we kind of are the Aluminum rod guys too.
Thanks!
-Kenny
I'll have the dimensions after the block is done machine work. Thanks!
-Kenny
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1601313
04/02/14 01:20 PM
04/02/14 01:20 PM
Alberta Canada
Alberta Canada
A bit of mock up when the heads showed up...
-Kenny
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1601314
04/02/14 01:57 PM
04/02/14 01:57 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
That is a cool car!
A few questions, pardon me if I missed the info in the thread.
1) Are you going to fill the block? From what I am told that is a lot of stroke for a stock 400 block. How have the other large stroke stock block engines you gys built held up if I may ask?
2) Do you have any specific plans on how you will utilize an .800" + lift cam with those heads? I would think you will need to use longer valves and work on the rocker shaft stands. I have had a tough time finding the right valve spring at .750ish lift on my Edelbrock Victor build.
3) I am curious why you chose not to go with a MW intake port considering the massive displacement of the engine?
Keep us updated!
Thank you for sharing.
Re: Joss Engines 542ci Low Deck Build Thread [Re: hemiiroc] #1601315
04/02/14 04:07 PM
04/02/14 04:07 PM
The Great White North
RAMM Offline
RAMM  Offline
Thanks!
-Kenny
My math shows approx .055" out of the hole @ 9.98" dht. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Joss Engines 542ci Low Deck Build Thread [Re: Jeremiah] #1601316
04/02/14 04:55 PM
04/02/14 04:55 PM
Alberta Canada
Alberta Canada
That is a cool car!
Keep us updated!
Thanks Jeremiah,
It will be a full water block still. The other builds have held up quite well. We have no reservations about putting the 4.5” stroke into the 400 block.
As for the lift, where the port stops working on the bench, We will do our best to get the valve open to where it will work best, if we need to run a little less lift, we will. One place we will have more room will be where a valve seal normally would be haha. I always get bashed for this, but none of our engine get valve seals. Even the 318 in my daily driver Volare wagon has no valve seals.
The MW head is the same casting, and these have been ported to MW size. So, no particular reason, this was the head we have.
-Kenny
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1601317
04/03/14 04:28 AM
04/03/14 04:28 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Kenny,
That is good to hear regarding longevity vs. CID. I have often heard that lots of stroke and RPM will kill a stock block in relatively short order. On the other hand there are quite a few great running engines of this nature that stay together so it has been somewhat of a confusing topic for me.
I am intrigued by the lack of valve stem seals. Is there anything special concerning the preparation of the valve guide? Standard clearance? My hurdle with the Edelbrock Victors was finding a 1.600 diameter valve spring that had compatible spring rates for seat and open pressures. This is using a cam with the following specs on my tunnel ram, pump gas 4.375x4.25 511. FYI it will use 1.7 ration rockers.
Cam Specs:
275/282 @ .050"
.448"/.436" Lobe Lift
111 LSA
240-260 closed
680-720 open
*In order to make this work +.050 locks must be used.
Lastly, I will be interested to see what you get for flow numbers out of the MW Victors. Will you be putting this engine on the dyno or straight to the killing floor?
Re: Joss Engines 542ci Low Deck Build Thread [Re: RAMM] #1601318
04/03/14 11:13 AM
04/03/14 11:13 AM
Alberta Canada
Alberta Canada
Thanks!
-Kenny
Sorry guys, that was a typo. The 4.56 stroke had a 6.535" rod. Not a 6.635
-Kenny
Re: Joss Engines 542ci Low Deck Build Thread [Re: Jeremiah] #1601319
04/03/14 02:16 PM
04/03/14 02:16 PM
Alberta Canada
Alberta Canada
Kenny,
Cam Specs:
275/282 @ .050"
111 LSA
240-260 closed
680-720 open
I'll keep you posted on the spring/retainer/keeper choice we make. It sounds like you are on the right path.
We will be running the guides as they came in the heads, with no seals. The engine will puff a little oil smoke on start up every once in a while but that's it. We have 200+ engines out there like that, haven't stuck a valve on one. A lot of these engines are industrial/agriculture engines that run A LOT of hours. One of our customers running one of our Oldsmobile irrigation engines has a short block from 1985 still I believe? (I wasn't born yet)
The 542 will be flogged on our old school engine dyno. Probably won't fine tune it there, as we can dial it in better in the car on the much newer chassis dyno. Thanks!
-Kenny
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1601320
04/09/14 02:41 AM
04/09/14 02:41 AM
Alberta Canada
Alberta Canada
Hello all, here are some more pictures of some of the goodies and block clearancing on the block.
Thanks!
-Kenny
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1601321
12/15/14 10:30 PM
12/15/14 10:30 PM
Alberta Canada
Alberta Canada
Just a little update as I have not been on here in a little while. The 542ci. is short block'd and the top end is coming together. Still need to do the rest of the porting on the heads. Customer's engines come first, so this has been slow going.
-Kenny
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1601322
12/15/14 11:43 PM
12/15/14 11:43 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Making it look like a 343 dual quad motor would be MAX cool.
The little old lady from Pasadena is back!
Re: Joss Engines 542ci Low Deck Build Thread [Re: Barnstorm] #1601323
12/16/14 03:14 AM
12/16/14 03:14 AM
Alberta Canada
Alberta Canada
You need to phone my dad at the shop. I'm sure you two would get along great. He actually was hogging out a dual 4 manifold for it. So, YES you will probably see this engine in that trim. We have the Victor 383 manifold as well, which will have an SV1 on it I'm sure. I did make him so decals to play the part on the valve covers
-Kenny
Re: Joss Engines 542ci Low Deck Build Thread [Re: Barnstorm] #1601324
01/14/15 05:14 PM
01/14/15 05:14 PM
Alberta Canada
Alberta Canada
The engine is a little bit on the back burner at the moment as we have been busy with other engines. (LS Chevy stuff dare I say!?) Hopefully we can put more time into it soon.
-Kenny
Re: Joss Engines 542ci Low Deck Build Thread [Re: StrokerAspen] #1601325
01/14/15 05:35 PM
01/14/15 05:35 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
I am interested in hearing how you plan to run 14.2-1 CR on 94 pump swill with meth.
Page 2 of 3 1 2 3
