Re: Hooking up MSD6, bypassing ballast
[Re: CoDart]
#1601098
03/31/14 01:19 PM
03/31/14 01:19 PM
RapidRobert
Hello Ori, To bypass the ballast you could connect the ign1 (run) blue wire circuit and the ign2 (crank) brown wire circuit together & run that connection to the coil positive primary terminal and to the MSD trigger wire which iirc is the small red one to power both the coil and the MSD in run and in start. You could T em together before (like you are considering) or after the bulkhead & also connect from that T to the blue wire to the alt field and to the reg top terminal in the triangle connector. You are powering up the coil the reg the alt field the MSD. Where is the black/yellow wire on the (blue I'm assuming) alt field terminal going to?
[Re: CoDart]
#1601099
03/31/14 01:28 PM
03/31/14 01:28 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
Since the MSD needs a clean 12v signal, I decided to splice into my Blue wire/Brown wires at the steering column. This eliminates any voltage drop from the stock connections under the dash, through the bulkhead and up to the ballast area.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: CoDart]
#1601102
03/31/14 03:17 PM
03/31/14 03:17 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Like said above...hooked the small red wire to a keyed 12 volt source...that wire turns the msd box on and off...
so hook it to your ignition switch...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: CoDart]
#1601105
03/31/14 11:29 PM
03/31/14 11:29 PM
RapidRobert
You have a brown going from the column up to the horizontle blue that connects an alt field (blue wire) terminal to the reg top terminal. You would need that to be hot in ign1 (run) so the reg/alt are powered in ign1 so it is charging while the eng is running so the wire that feeds that would need to be the blue ign1 circuit. IF that brown is the same circuit as the ign2 "start" brown it'd be dead as soon as you let off the key. The brown wire "ballast bypass" on the downstream end of the ballast would be getting some current thru the ballast (what the coil sees) in ign1 run but it'd be reduced & not correct to feed the reg/alt. I think what I posted earlier on the MSD wiring was incorrect so I retract that. My bad.
