Brake lines...the flared nuts
#1601088
03/31/14 11:06 AM
03/31/14 11:06 AM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
Went to go swap out the caliper lines on this 72 RR and the previous owner rounded the edges off with what I assume to be vice grips or an open end wrench. I can't get my flared nut wrench to grab on to anything. I have been soaking them with PowerLube all day. I know we should be replacing them, the whole set if like $149 from InlineTube. Can I take a mini torch to the flared nut and heat it up to crack it loose with vice grips or am I better just cutting off the whole section and replacing it. I can assume that since the fronts are like this, the rears are probably just as bad.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Brake lines...the flared nuts
[Re: Pyper70]
#1601089
03/31/14 11:39 AM
03/31/14 11:39 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Ive heated them at work to get them off.Just have to be careful that they dont get too hot.I also work them back and forth to get them to turn.Usually the flare nut rusts on the flare and thats why they wont come out.I have lots of experience as in the rust belt frozen parts and the norm.If its the hoses you can also clamp a good set of vice grips on the flare nut.Take the clip off the hose and back the hose off the nut instead of trying to turn the nut off the hose.Then when its off work it loose and use a bit of anti sieze before install.Rocky
Chrysler Firepower
[Re: 6PakBee]
#1601092
03/31/14 04:41 PM
03/31/14 04:41 PM
therocks
Niles , Ohio
6Pak you must have rust issues out there too.Here its a daily thing.I even antisieze my bleeders when I put them in.My buddy that got me using it buys 10 or 20 pound cans at his fab and machine shop.He works on a lot of farm and oil well stuff.So it goes quick.Rocky
Chrysler Firepower
[Re: Pntastar69]
#1601093
03/31/14 05:45 PM
03/31/14 05:45 PM
Pyper70
Athens, Greece
hmm...right stuff has a right price...Stainless Steel lines...Looks pretty good for the entire kit
