1966 HEMI block stampings Help ID #1600886
03/30/14 11:02 PM
03/30/14 11:02 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
I have a 1966 426 HEMI block 2468330-2 cast in 1 18 66 and a assembly date stamp on the bottom oil pan rail by the starter ear 3 27 66 and on the engine ID pad it is stamped BH426 WT with a Maltice cross and 4 2 23 What does the 4 2 23 mean? It does Not have a VIN stamped on the back of the block by the transmission mount.
Thanks Brian
Re: 1966 HEMI block stampings Help ID [Re: Bishop] #1600887
03/30/14 11:38 PM
03/30/14 11:38 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
That is the actual assembly date of the engine, April 2nd, 1966, the 23 is the build sequence
B = 1966 model year
H = Hemi Engine
426 = Cubic Inches
WT = Water Tested block
3-27-66 Pan rail is the original date the block was machined
Maltese Cross = .001" undersized bearing shells
*No VIN# was stamped into any block until the 1968 model year
Re: 1966 HEMI block stampings Help ID [Re: ScottSmith_Harms] #1600888
03/31/14 12:37 AM
03/31/14 12:37 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I find it interesting that:
casting date 1/18/66 was a Tuesday
machining date 3/27/66 was a Sunday * what other numbers are stamped here?
assembly date 4/2/66 was a Saturday
Average '66 model year HEMI vehicle production was in the vicinity of 20 cars per day combined at 3 plants.
GOT PICS?
Re: 1966 HEMI block stampings Help ID [Re: ScottSmith_Harms] #1600889
03/31/14 12:43 AM
03/31/14 12:43 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
this would be undersized crank & oversized bearings
Re: 1966 HEMI block stampings Help ID [Re: 6bblgt] #1600890
03/31/14 01:44 AM
03/31/14 01:44 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes Dan, I agree, got it a wee bit wrong off the top of my head
