rattlin' seatbelts
#160087
12/02/08 11:21 AM
12/02/08 11:21 AM
Posts: 7,066 portland or
new bee
Richard Cranium
Richard Cranium
portland or
My rear seatbelts were restored by snakeoyl, and are installed just like the fatory did them (1969 Super Bee). The three of them are clipped to the lip at the base of the rear seat and pulled taut. However, the belt buckles are rattling, mostly over rougher roads. Is there an anti-rattle bushing or something else nakeoyl might have left out?
*1969 383 4sp. Super Bee *1966 Alfa Romeo Giulia Sprint GT *1965 Porsche 356C *2004 VW Passat Wagon *2004 Mini Cooper S *1967 Jaguar E-Type FHC
A mall cop is in our midst.
Re: rattlin' seatbelts
[Re: ECS]
#160089
12/02/08 12:24 PM
12/02/08 12:24 PM
new bee
Richard Cranium
Richard Cranium
portland or
It's comimg from the buckle. Thanks for the insight! Where might I find the correct foam for this?
[Re: new bee]
#160090
12/03/08 05:38 PM
12/03/08 05:38 PM
Posts: 2,304 WI
RestoRick
WI
Your local "helpful hardware man"... Find some adhesive backed black foam weatherstrip to cut off approx. 1/2" x 3/4" tabs. Thickness was originally a bit over 1/8" so 3/16" will do it. You want the harder, more dense stuff, not the softer variety. Position them on the buckle cover so they align with the knurled shaft and you should be "rattle-less"... Rick
[Re: new bee]
#160091
12/03/08 07:09 PM
12/03/08 07:09 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
It's hard to believe the snakeoyl big bucks seatbelt resto did'nt include the anti- rattle foam... ..For the money you have in them you should'nt need to do anything to them.. ...Don't miss the chance to give them a call and correct it for any future mopar customers....
[Re: RestoRick]
#160093
12/04/08 11:55 AM
12/04/08 11:55 AM
new bee
Richard Cranium
Richard Cranium
portland or
thanks, guys.
timing is everything. if i started restoring my super bee this winter (not 3 years ago), i would have used a new amd quarter panel for the passenger side. i would have also ordered seat belts from bea rather than snakeoyl. the snakeoyl belts are really nice looking, but they were expensive...and they rattle.
[Re: new bee]
#160094
12/07/08 09:02 PM
12/07/08 09:02 PM
new bee
Richard Cranium
Richard Cranium
portland or
Voila! About .05 cents worth of foam and they are rattle free. Thanks!
[Re: new bee]
#160095
12/07/08 09:22 PM
12/07/08 09:22 PM
Posts: 2,304 WI
RestoRick
WI
[Re: new bee]
#160096
12/08/08 07:46 PM
12/08/08 07:46 PM
Posts: 1,711 USA
ECS
David Walden
David Walden
USA
Here is a picture showing and original and the unit(s) that we are reproducing. We use the exact (firm) foam stock that the manufacturer provided and the 4 mil. protective clear overlay that was applied on the top to keep the foam from being damaged. The thickness is exact to the originals so they provide the same protective function and appearance. The cost to do a complete seat belt set is $6.
