Lowering Motor and Trans, stock bodied car
#1600796
03/30/14 06:02 PM
03/30/14 06:02 PM
Posts: 240 Ft. Wayne, IN.
QTR MILR
Ft. Wayne, IN.
Has anyone lowered the motor and trans on a stock bodied street/strip car?? Everything is so tight in my 69 Satellite it's nearly impossible to work on.... I'd like to lower the motor and trans about 1 inch. I've modded the k-frame and I am using a motor plate in the front. So that's easy enough. I'm looking at cutting the cage for the trans mount off of the crossmember and welding it 1 inch lower.... Any problems/drawbacks to this?? Thanks!!
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Lowering Motor and Trans, stock bodied car
[Re: QTR MILR]
#1600797
03/30/14 06:18 PM
03/30/14 06:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
It does cause a couple of issues.. might not be bad for you... when you lower that weight it makes it harder to transfer the weight to the rear and you need to look at the ground clearance.. I raised my car up 1" to make it a BIT easier to get in the trailer ![](/ubbthreads/images/graemlins/wave.gif)
[Re: QTR MILR]
#1600798
03/31/14 01:52 AM
03/31/14 01:52 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I guess you have never worked on a Abody 440. Your Satellite should have much more room.
I wouldnt want to lower it as it will hurt weight transfer like Mike states. Id try to figure out a different approach.
My motors actually raised about 3/4" by the motor mounts. Stick with what you have IMO Your heavy Satellite could use it. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: QTR MILR]
#1600801
03/31/14 03:11 PM
03/31/14 03:11 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
What are you trying to do? B-Bodys have a decent amount of room to work with. I guess you could remove some of the inner fender for better access.
[Re: Mr.Yuck]
#1600802
03/31/14 07:20 PM
03/31/14 07:20 PM
QTR MILR
Ft. Wayne, IN.
The biggest issue with my car is clearance around the transmission. Trying to put in a sheild and it seems like there isn't room for it.... I've trimmed the pinch weld area but it's tight behind that!! There is barely any clearance between the driveshaft and the top of the loop... The loop is stuffed up as high as I can get it. ![](/ubbthreads/images/graemlins/shruggy.gif) Almost seems like the trans mount might be too tall....
Scott
[Re: Mr.Yuck]
#1600804
03/31/14 10:18 PM
03/31/14 10:18 PM
QTR MILR
Ft. Wayne, IN.
IIRC the loop is Summit Racing... It's up against the floor. If there was no loop there would be maybe 1-1/2 inches from the floor to the top of the driveshaft....
Scott
[Re: HOT IN AZ]
#1600806
03/31/14 11:31 PM
03/31/14 11:31 PM
MR_P_BODY
I know this won't work for you but a trick used by some racers running 62-65 B-body cars is to install a 66-67 K-member which lowers the engine in the car. Just food for thought!
He is on a front plate... that part is super easy.. the trans brace isnt hard either... its just a matter if he wants to ![](/ubbthreads/images/graemlins/wave.gif)
