69 Dart S/Gas S/pro Car #160067
12/02/08 07:54 AM
12/02/08 07:54 AM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
Hi !
Here`s some of the stuff my (formerly Tweety`s) 557 Hemi`s got.
Kieth Black block 4.375" bore - Barton tweeked
JE Custom pistons 11.1 : 1 built for a 200 shot (maybe some day )
Bryant 4.625" stroke crank w/2.200" Journals
RBRE Race Hemi rods (Oliver) 6.86"
RBRE 896 Series tool steel tapered pins 1.031" x 2.750"
ATI Damper
RBRE 896 Series billet oil pump
Milodon dual line swing P/U
Charlies Pan
Mopar Perf heads - Barton tweeked O ringed.
RBRE 896 series S/S 2.250" Int.
RBRE 896 series S/S 1.940" Exh.
Comp Cams 1.540" Double springs w/ damper 450# @ 1250
Comp Cams 10 Deg. retainers w/ Manley cups
Bullet Racing Cams Int. 278@.050" / Exh. 284@.050 - .754"Int / .722"Exh.
Comp Cams Roller lifters
RBRE 2000 Rocker system w/ oiling updates
IRC 3/8" pushrods
RBRE Single plane Intake
Gary Williams 1050 full race 1150 CFM w/annular boosters and reworked fuel circuits.
Hooker A-Body Hemi 2 1/4" x 4" headers
The car is 2750 with me in it, has a light weight front half and has been back halfed with ladder bars and a floating 44" Dana 60 w/4.10 Stange gears, spool and axles and driveshaft w/ 1350 u-joints. I run 14.5/32/15 Goodyears for rubber. The car has Wilwood discs all around , 12 point mild steel cage . The front end including the bumper is glass , the doors and decklid also . The trans is a J.W. Perf. Glide ' with Ultra bell adapter , The Wheel flywheel , J.W. transbrake , and 4600 stall 9" convertor. I`m using a Hurst Quarter Stick with pistol grip shifter also Hurst Linelock.
How fast will she go HuhHuh? Not done buildin' er' yet !!! It was dyno`d at Bartons at 874 hp @ 6800 and 750 ft/lbs @5350 ....in a 2750# car , do the math !
CAN`T WAIT !!!!!!!!
Chryco Wink
http://ca.youtube.com/watch?v=x9jxA83YeM0
http://ca.youtube.com/watch?v=9rG0doYzstE Dyno Pulls @ RBRE w/ David Barton
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: 69 Dart S/Gas S/pro Car [Re: chryco] #160068
12/03/08 12:08 AM
12/03/08 12:08 AM
Jacksonville Florida
elitecustombody Offline
sounds like it will be a blast to run
Re: 69 Dart S/Gas S/pro Car [Re: elitecustombody] #160069
12/03/08 12:41 PM
12/03/08 12:41 PM
Millersville, PA
HemiChallenger Offline
Millersville, PA
Nice looking car you got there...
Steve
