2001 Dodge 3500 Rims #1600637
03/30/14 03:26 PM
03/30/14 03:26 PM
fort erie ontario
3
365mike Offline OP
365mike  Offline OP
fort erie ontario
Purchased a set of 6 used rims to mount my winter tires on. Could not find a set of 7 hole factory rims (7 holes in rim, 8 lugs of course), they are available only on 2001 & 2002 model years. The rims I purchased were from a Ford cube van, same bolt spacing, offset and centre hole. The recycling yard I bought them from claimed they spun the rims w/o tires & they were ok for balance. Had my tires installed & blanced at yard where purchased rims. After installing the wheels on truck, it shook like crazy, especially at & approaching highway speeds. Had steer tires balanced at another shop...they were out of balance. Shake improved but still there. Had the 4 rear tires balanced, still shakes. Driveline sound, front end tight, winter tires on factory rims were no problem season before. About to put factory rims & all seasons back on, winter almost over here. The question is, has anyone else experienced this problem with Ford or other rims on their 3500?
Re: 2001 Dodge 3500 Rims [Re: 365mike] #1600638
03/31/14 01:20 AM
03/31/14 01:20 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
your Dodge is rejecting the Ford rims..
I am truckless..
