exhaust on e-body/b-bodys with tti headers #1600442
03/30/14 09:57 AM
03/30/14 09:57 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
For the guys thats using the tti headers w/exhaust what or you all using for tubing/mufflers?The stransiual tubeing from from round to oval for ground clearance?With tti headers they or made with a slight angle towards the ground The car in ? is an e-body with 2-2 1/8 headers with 3 1/2" ehaust i would like too lower the car some but don't see that happening ith this exhaust happening
Re: exhaust on e-body/b-bodys with tti headers [Re: racerx] #1600443
03/30/14 12:16 PM
03/30/14 12:16 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
3.5 inch kit from Pypes with MagnaFlo Race Mufflers:
Re: exhaust on e-body/b-bodys with tti headers [Re: racerx] #1600444
03/30/14 01:44 PM
03/30/14 01:44 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The MoPig has TTI 2" B/E-body headers w/ their full 3" X-pipe system using Dynomax Ultraflow mufflers & matching tips.
I have one of the bolt-on driveshaft loop kits that required two sections to be welded together because the bolt heads caused clearance issues. I'm pretty sure that's because Stage VI & Victor heads have the exhaust ports raised about 3/8" compared to OEM to result in that issue.
EDIT: Just re-read your original post and saw you're using 3.5" exhaust, so my comments probably don't really apply here.
Re: exhaust on e-body/b-bodys with tti headers [Re: BradH] #1600445
03/30/14 08:13 PM
03/30/14 08:13 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run a full TTI 3" system to the rear bumper with the X-pipe and Dyno-Max Ultra-Flows. And I use 2" TTI headers. On my 63 I have plenty of clearance. Ron
Edit: I just did the same thing as Brad and now realize you have 3.5 and I have 3". Sorry about that. Ron
Re: exhaust on e-body/b-bodys with tti headers [Re: gsmopar] #1600446
03/30/14 10:17 PM
03/30/14 10:17 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Do you use the TTi headers with those pypes?And if so how do they fit against the flooe pan? those look nice ..........
Re: exhaust on e-body/b-bodys with tti headers [Re: racerx] #1600447
03/31/14 01:28 PM
03/31/14 01:28 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Yes, TTi Headers (2in primary) and Pypes 3.5 inch pipes. They're tight to the floor (enough space to keep from burning). I can take some more pics tonight when I get home if you'd like. Anything in particular?
Re: exhaust on e-body/b-bodys with tti headers [Re: gsmopar] #1600448
03/31/14 10:31 PM
03/31/14 10:31 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Do you use the TTi headers with those pypes?And if so how do they fit against the floor pan? those look nice ..........
Yes........if all poseable can get some pics right behind the collector where the pipes run through the frame cutouts just before the trans crossmember..........Thaxs
Re: exhaust on e-body/b-bodys with tti headers [Re: racerx] #1600449
04/01/14 01:58 PM
04/01/14 01:58 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Sorry! I got busy last night. I'll get you some pics today when I get home.
Re: exhaust on e-body/b-bodys with tti headers [Re: gsmopar] #1600450
04/02/14 02:06 AM
04/02/14 02:06 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Re: exhaust on e-body/b-bodys with tti headers [Re: gsmopar] #1600451
04/02/14 08:07 PM
04/02/14 08:07 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thax. u sir. thats what i wanted to see now 1 last ?did u happen to weigh the exhaust,and if so how much?........Thax.
Re: exhaust on e-body/b-bodys with tti headers [Re: racerx] #1600452
04/02/14 10:48 PM
04/02/14 10:48 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I didn't weigh it, but I bet you could look up the weight of the parts individually online.
Re: exhaust on e-body/b-bodys with tti headers [Re: gsmopar] #1600453
04/03/14 09:49 AM
04/03/14 09:49 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
K.......Thax.
Re: exhaust on e-body/b-bodys with tti headers [Re: racerx] #1600454
04/03/14 10:04 AM
04/03/14 10:04 AM
an8sec70cuda Offline
I had the TTI 2" to 2.125" step headers for Indy heads on my cuda w/ a 4" exhaust system. Same headers and engine are now in my road runner.
Now have TTI 2.25" primary, 4" collector hemi headers w/ 4" exhaust on it.
Both systems were put together w/ mandrel bends I got from NAPA.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: exhaust on e-body/b-bodys with tti headers [Re: an8sec70cuda] #1600455
04/03/14 06:22 PM
04/03/14 06:22 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Hows your ground clearance with the 4" tubeing?Does it fit well inside the notch cutouts in the frame?........Thax.
