Duster disc brake parts #1600358
03/29/14 11:43 PM
03/29/14 11:43 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
Want to convert my 75 Duster to disc brakes.Can I use brakes from a Volare or a St Regis or New Yorker. What parts will work properly
Re: Duster disc brake parts [Re: moparmikethree] #1600359
03/30/14 12:50 AM
03/30/14 12:50 AM
The volare spindles will fit & iirc the horizontle spindle height is 3/8" taller than the A spindles but people have sucessfully used them. EDIT If you do have the smaller UBJ, Doc has sleeve spacers so you can keep the same UCA/UBJ.
Re: Duster disc brake parts [Re: RapidRobert] #1600360
03/30/14 01:18 AM
03/30/14 01:18 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Robert is correct the F body spindles will bolt right in place. Make sure your old drum brakes were 10" (big ball joint) otherwise you may have to change upper control arms.
You also want to double check the bolt pattern as some bodies did receive the 4" drum brakes up into the middle 70's. The only ones I've seen were 4 doors.
...FAFO...
Re: Duster disc brake parts [Re: skicker] #1600361
03/30/14 01:37 AM
03/30/14 01:37 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
75 A's all had the large ball joint uppers from the factory.
Typically all A's from 73 up had large upper ball joints, drum or disc brakes, didnt matter. There were some "use up the parts in stock" hold overs so some 73's reportedly got the small ball joint uppers. Parts books show the availability.
ALL A bodies with 4 wheel drum brakes were small bolt pattern and had a 7-1/4 rear.
F, M, J and late B's make great disc brake donors. Spindles out plus master/dist-prop valve.
Re: Duster disc brake parts [Re: moparmikethree] #1600362
03/30/14 03:22 PM
03/30/14 03:22 PM
AndyF Offline
AndyF  Offline
For drag racing you can put disc brake rotors right on the'75 Duster drum brake knuckles. Just need a caliper bracket to hold the caliper. That combo makes a nice lightweight setup. For street driving it is better to swap in disc knuckles.
The late model drum knuckles are worth some money so don't toss them. I used to use those knuckles for my Viper conversion since they were lightweight but had the large bearings.
