Six Pack carb numbers? #1600288
03/29/14 09:28 PM
03/29/14 09:28 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Does anyone know where I can find the correct carb numbers for a 70 auto six pack car? I'm getting ready to send them off to be redone. And want to make sure these are the correct carbs. Thanks
Re: Six Pack carb numbers? [Re: 70VcodeCoronetRT] #1600289
03/29/14 09:30 PM
03/29/14 09:30 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Post your numbers and I'll tell you what you have. If you post photos it's easier, I can decode the dates as well.
Re: Six Pack carb numbers? [Re: ScottSmith_Harms] #1600290
03/29/14 09:45 PM
03/29/14 09:45 PM
Nebraska
Nebraska
Great thanks List-4393-1 Might be a 4383. Hard to tell. List-4394-1 This one is really hard to read. So it might be off. And the center is List-4375-1. I was told this is a 4 speed carb? My car is an auto. So if true it must of been swapped at some point. Thanks for your help.
Re: Six Pack carb numbers? [Re: 70VcodeCoronetRT] #1600291
03/29/14 09:48 PM
03/29/14 09:48 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
List-4393-1 -1969 Front
List-4383 -1970 Rear
List-4394-1 -1969 Rear
List-4375-1 -1970 Manual Center
Re: Six Pack carb numbers? [Re: ScottSmith_Harms] #1600292
03/29/14 10:03 PM
03/29/14 10:03 PM
Nebraska
Nebraska
Thanks!! I guess I don't have one correct carb. Is it unheard of to see the 69 carbs on a 70? What would be the correct carbs for a 70 auto? Thanks again.
Re: Six Pack carb numbers? [Re: 70VcodeCoronetRT] #1600293
03/29/14 10:08 PM
03/29/14 10:08 PM
Nebraska
Nebraska
Re: Six Pack carb numbers? [Re: 70VcodeCoronetRT] #1600294
03/29/14 10:08 PM
03/29/14 10:08 PM
Nebraska
Nebraska
Re: Six Pack carb numbers? [Re: 70VcodeCoronetRT] #1600295
03/29/14 10:09 PM
03/29/14 10:09 PM
Nebraska
Nebraska
Re: Six Pack carb numbers? [Re: 70VcodeCoronetRT] #1600296
03/29/14 10:23 PM
03/29/14 10:23 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I can't say it never happened (69 carb on a 70 engine, etc.) but I've never seen a documented original that way, pretty long odds against that one.
Re: Six Pack carb numbers? [Re: ScottSmith_Harms] #1600297
03/29/14 10:26 PM
03/29/14 10:26 PM
Nebraska
Nebraska
Thanks Now I have to decide to have these done or look for the correct list numbers for a 70 auto car.
Re: Six Pack carb numbers? [Re: 70VcodeCoronetRT] #1600298
03/30/14 05:18 PM
03/30/14 05:18 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
I believe I saw some in the engine parts for sale section. Also, pm sent
Re: Six Pack carb numbers? [Re: RP's R/T's] #1600299
03/30/14 11:06 PM
03/30/14 11:06 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
This may help as well from the '70 Service Manual. In addition to the car being an auto or manual, the numbers were also different between California ("ECS") or all other non-California cars ("CAS")
Assuming your car is a non-California car, then the correct numbers for an auto 440 would be:
R- 4383
C-4376
F-4382
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Six Pack carb numbers? [Re: 70VcodeCoronetRT] #2569664
10/26/18 10:38 AM
10/26/18 10:38 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Scott
I have a set,
front, List 4671
center, List 4375
rear, List 4872
