Duster rear suspennsion #1600201
03/29/14 05:58 PM
03/29/14 05:58 PM
NC
chris3 Offline OP
chris3  Offline OP
NC
Duster has spool and 4.88 gears. Has leaf springs. Previously body would lift about 5 1/2 inches. Last run drivers side lifted as normal but passenger side just sits and leans all the way down track. Stationary car sits level and only leans under power. Pulled the axles and no problems. Shock is workiing fine. Don't see a broken spring.
Re: Duster rear suspennsion [Re: chris3] #1600202
03/29/14 06:13 PM
03/29/14 06:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Check the spring perch it could be ripping free or
the right spring is shot in the front allowing it
to flex alot... the front holds the axle in place and
gives it the lift... the rear of the spring is what
holds it up... if it started sorta quick I would look
at the perch first... also is this a dana rear end..
the tube can be rotating in the housing
Re: Duster rear suspennsion [Re: MR_P_BODY] #1600203
03/29/14 06:37 PM
03/29/14 06:37 PM
NC
chris3 Offline OP
chris3  Offline OP
NC
Not a Dana. 8 3/4
Re: Duster rear suspennsion [Re: chris3] #1600204
03/29/14 06:39 PM
03/29/14 06:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not a Dana. 8 3/4
Look at the spring perch to see if its ripping off
Re: Duster rear suspennsion [Re: MR_P_BODY] #1600205
03/30/14 07:28 PM
03/30/14 07:28 PM
NC
chris3 Offline OP
chris3  Offline OP
NC
Mr. Peabody thank you. You are correct. The welds on the spring perch where they were relocated have broken. Thank you again for your response
Re: Duster rear suspennsion [Re: chris3] #1600206
03/30/14 07:31 PM
03/30/14 07:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No problem... glad you found it before you had MAJOR
issues if it ripped free... you should box them in
