Upper Ball Joint Installation #160017
12/02/08 12:45 AM
12/02/08 12:45 AM
Arizona
68CoronetRT Offline OP
Arizona
Do I really need to buy the $40 socket to install the upper ball joints in my 68 B-body?
Are there any other options?
Re: Upper Ball Joint Installation [Re: 68CoronetRT] #160018
12/02/08 12:48 AM
12/02/08 12:48 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
nope a pipe wrench or Crescent wrench should do it..
when re installing pad ball joint with cloth of some sorts..to prevent any burrs..
Re: Upper Ball Joint Installation [Re: 68CoronetRT] #160019
12/02/08 12:52 AM
12/02/08 12:52 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
The socket might not be the cheapest way, but it is correct and easier in the long run in my experiance at least..
Re: Upper Ball Joint Installation [Re: 340dart4spd ] #160020
12/02/08 12:54 AM
12/02/08 12:54 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Aren't they supposed to be torqued to some value? If that is the case then a socket would be almost mandatory.
You could always buy the socket and then sell it when your done?????
Re: Upper Ball Joint Installation [Re: Neil] #160021
12/02/08 01:27 AM
12/02/08 01:27 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Most any shop thar does front end work will have one, talk to the mechanic, leave a deposit & he'll probably let you use it..
Re: Upper Ball Joint Installation [Re: 68CoronetRT] #160022
12/02/08 03:12 AM
12/02/08 03:12 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
A large Cresent wrench with a 3' piece of pipe for leverage works.
Re: Upper Ball Joint Installation [Re: Lefty] #160023
12/02/08 07:31 AM
12/02/08 07:31 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Buy the socket.That or most big chains have them to rent in their loan a tool program.Slip once with a ceresent wrench and bust your hands and you will think 40 bucks is cheap.Rocky
Chrysler Firepower
Re: Upper Ball Joint Installation [Re: therocks] #160024
12/02/08 01:10 PM
12/02/08 01:10 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Thats my thinking too.
Re: Upper Ball Joint Installation [Re: CYACOP] #160025
12/02/08 01:25 PM
12/02/08 01:25 PM
for a one time deal save your money use a wrench & with care you'll be fine. I think the spec is 125 lbs but on an upper ball joint just crank it tight.
Re: Upper Ball Joint Installation [Re: 1_WILD_RT] #160026
12/02/08 01:30 PM
12/02/08 01:30 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
That's what I did... an old guy in town had one and I paid him $20 to use it. It can be done another way, but it took the socket, a breaker bar and a cheater pipe to break my old one loose. I'd hate to try that with a pipe wrench. if you are just going back together with clean new stuff, it's still nice to have the right tool for the job. Some parts houses have them for loaners....
The Blue Goose
My instagram: Bossride
Re: Upper Ball Joint Installation [Re: BossRide] #160027
12/02/08 02:49 PM
12/02/08 02:49 PM
None
71rm23 Offline
71rm23  Offline
None
Re: Upper Ball Joint Installation [Re: 68CoronetRT] #160028
12/02/08 02:59 PM
12/02/08 02:59 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I bought a set of 2 for bigger and smaller one... for 50.00
well worth it if you do any kinda work yourself....
Re: Upper Ball Joint Installation [Re: 68CoronetRT] #160029
12/02/08 03:03 PM
12/02/08 03:03 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I've done it both ways. Socket is much better. If you have to buy one do it. You probably have other Mopar buddies. You can get your money back by renting it to them for a small fee. Keep the amount small; you'll keep your friends and still come out OK. Keep the control arm on the car and use an impact wrench for removal. Installation torque is 125 ft.lbs. minimum. I usually go 150 ft.lbs.
Re: Upper Ball Joint Installation [Re: 5spdcuda] #160030
12/02/08 03:20 PM
12/02/08 03:20 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
That reminds me... I forget mine every time I go to buddies house.... Hope he didn't rent it out
Re: Upper Ball Joint Installation [Re: 340dart4spd ] #160031
12/02/08 05:56 PM
12/02/08 05:56 PM
Ontario, Canada
8
84Stepside Offline
84Stepside  Offline
Ontario, Canada
i tried a pipe wrench, it was a PITA IMO, i rented a socket twice now, when i took it back they gave me all my money back both times, and i didn't even buy my parts there lol. Socket is way better and safer.
Re: Upper Ball Joint Installation [Re: 84Stepside] #160032
12/02/08 08:17 PM
12/02/08 08:17 PM
Cochise County Arizona
SPWC Offline
SPWC  Offline
Just dont try pessing them in or out like a guy did when I was working at a parts house,He couldnt figure out what he had done wrong.
Re: Upper Ball Joint Installation [Re: 68CoronetRT] #160033
12/02/08 11:35 PM
12/02/08 11:35 PM
Scottsdale, AZ
K
kenz Offline
kenz  Offline
K
Scottsdale, AZ
Where in AZ are you? I have one you can borrow. I'm in North Scottsdale.
PM me if you're interested.
Thanks,
Ken
Mopars Unlimited of Arizona
www.moparsaz.com
Re: Upper Ball Joint Installation [Re: 68CoronetRT] #160034
12/03/08 12:35 AM
12/03/08 12:35 AM
PA
moparboy66 Offline
moparboy66  Offline
PA
Use the proper socket on a 3/4" breaker bar.
I just go to Advance Auto and "rent" their loaner ball joint replacement tool kit.
They tell me to return it within 90 days, then they credit the full $150 and change back to my credit card.
No fuss at all, but I did go to Harbor Freight and buy a 3/4 breaker bar for around $12 or so. I've used the breaker bar with a 3/4 to 1/2 adapter afew times, so its paid for itself too.
Re: Upper Ball Joint Installation [Re: moparboy66] #160035
12/03/08 05:08 AM
12/03/08 05:08 AM
None
71rm23 Offline
71rm23  Offline
None
Re: Upper Ball Joint Installation [Re: 71rm23] #160036
12/03/08 11:14 AM
12/03/08 11:14 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I made my socket, it's done three sets so far and still looks good. I use Kroil and a impact wrench, it sure beats a breaker bar and cheater.
