Re: From hughes engine page
[Re: SpareParts]
#1599982
03/29/14 04:55 AM
03/29/14 04:55 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
And just think April 1 is only a few days away....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: SpareParts]
#1599983
03/29/14 05:00 AM
03/29/14 05:00 AM
Posts: 1,418 Mcallen, TX
SB449VALIANT
Mcallen, TX
I am looking forward to seeing the potential these things have. Should be able to kind of bridge the gap between W7 8 9 and standard Eddie's or W2
Same here, let's see how is turns out....looks like needs some type of jesel/ t&d rockes, custom headers, etc...
If some of you want to give them a shot and buy them, send them to Diamond pistons please......
[Re: SB449VALIANT]
#1599990
03/29/14 10:02 AM
03/29/14 10:02 AM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
Same here, let's see how is turns out....looks like needs some type of jesel/ t&d rockes, custom headers, etc... the ad says standard BB rockers and 1.55 springs. 2.15x1.60 valves!
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: Leigh]
#1599993
03/29/14 02:21 PM
03/29/14 02:21 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Semi finished casting. Give a pair like those to a shop, and cringe at the final cost.
This is why I think people will still look to big W heads to make power
[Re: Leigh]
#1599994
03/29/14 05:11 PM
03/29/14 05:11 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
From the hughes webpage...
These heads will use standard big block rocker arms. Four versions are available; bare, bare with valves, complete (for hydraulic/flat tappet cams and solid roller cams) and Pro Port Raw. End-seal spacers are provided.
[Re: Sixpak]
#1599995
03/29/14 05:24 PM
03/29/14 05:24 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Return to Parts List Category : Small Block"LA" 273,318,340 and 360 engines : Cylinder Heads, Aluminum : Stock Out of Box EDE 61749 SB VICTOR PRO-PORT VERSION UNDERSIZE PORTS/FULL CORNERS ON INTAKE ENTRY/NO CHMBR OR P.ROD TUNNELS $0.00 Edelbrock expects to make the first production run of these heads April of 2014. Victor Pro-Port Raw Small-Block Chrysler Victor Small-Block Chrysler (For LA Engines) Specs and more info at bottom of the page. These new Victor Series cylinder heads are for use on 1967-1989, 318-360 c.i. Chrysler LA engines. They feature fully CNC ported 58cc combustion chambers and have an intake port volume of 225cc. These heads are an in-line valve design incorporating a 16° valve angle (stock is 18°) for improved air flow and increased power levels over heavily ported stock versions. They also feature the Chrysler W5 bolt pattern and have raised exhaust ports. The intake port has also been raised approximately 3/4" and the flange has also been extended to accommodate a stock (race) intake manifold such as our Super Victor #2815. Finally, a 5.56" overall length valve (+0.600" from stock) and raised rocker cover permit larger port cross-sections than in the stock head. These heads will use standard big block rocker arms. Four versions are available; bare, bare with valves, complete (for hydraulic/flat tappet cams and solid roller cams) and Pro Port Raw. End-seal spacers are provided. Flow Numbers as tested by Edelbrock's SuperFlo SF-1020 flow bench (We will post numbers from our flow bench as soon as possible.) #61779 Valve Lift .100" .200" .300" .400" .500" .600" .700" Intake 62 119 175 225 251 260 - Exhaust 52 105 142 169 185 190 - I hate to rip on a head before its out but these flow number for a 225cc runner head have to be wrong. The 225@.300 looks ok but boy are the rest LOW. Usually they advertise high and end up much lower. Looks like our pistons will need some new valve notches to but I will be in line for a set asap.
[Re: SB449VALIANT]
#1599998
03/29/14 09:26 PM
03/29/14 09:26 PM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
The very last set of w5 erson's .... Lucky boy!
.... nope, in 2007 after months of trying I was finally able to talk to Steve Tanzi and he had two sets left, one of which we purchased. Nice set of rockers for $700.
These heads are still capable of pumping air (sold them a few years ago)....unlike our other pair that liked to pump coolant too, time and time again. That was the reason for selling the set we still had. We actually were waiting for the Ebrock head to come out, but it never happened, and we moved on.
[Re: J_BODY]
#1599999
03/29/14 09:53 PM
03/29/14 09:53 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have one brand new W5 sitting in the shop and if i find a untouched mate to it will port them and throw them on something.
