Finished Up My Little Trailer
#1599711
03/28/14 03:47 PM
03/28/14 03:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I finished it up yesterday.. this is what I plan to pull behind the Rampage for Drag Week and any other times that I need to carry any stuff... just no room for things of any size in the cab... and there isnt any bed under the tonneau cover... the back light in the center is also the center leg to support the slide out
Re: Finished Up My Little Trailer
[Re: MR_P_BODY]
#1599713
03/28/14 03:50 PM
03/28/14 03:50 PM
MR_P_BODY
Last EDIT as you can see that the third light is the leg to help support the slide out.. its pinned and it slides out then I flip it over and pin it again(so I dont loose the pin)
[Re: MR_P_BODY]
#1599716
03/28/14 03:59 PM
03/28/14 03:59 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
You do nice work That should do all you need. I have been looking at bigger trailers to haul car show stuff for my club, but the bigger you go, the heavier you have to make tow vehicle, the hitch, electric brake controller, etc. etc.. So in the end most of the weight is just in the trailer and not in what you need to move
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1599717
03/28/14 04:08 PM
03/28/14 04:08 PM
MR_P_BODY
I made this a VERY precise size... the total length is 1/2" shorter than the height of my big trailer so I can stand it up in the big trailer and the box front wall is back just enough so if it jack knifes the box cant hit anything on the car... the height of the box is just tall enough to stack two of my rear tires IF I plan on changing tires... I did the slide out just for ease of getting at junk
[Re: bonefish]
#1599719
03/28/14 04:36 PM
03/28/14 04:36 PM
MR_P_BODY
Oh I forgot to say... the spare tire mount on the tongue is also the mount for a vise that drops in... I tried to make everything have multiple uses... I didnt get a pic of the vise in place... but so many times at the track I've needed a vise and end up clamping the part or what ever to to my counter top or any place that will work... its just a small 4" vise but works
[Re: MR_P_BODY]
#1599720
03/28/14 06:13 PM
03/28/14 06:13 PM
dogdays
Pretty Darn Cool !!!
R.
How about a small barbecue grille that bayonets in, in place of the vice?
[Re: MR_P_BODY]
#1599721
03/28/14 06:23 PM
03/28/14 06:23 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
That looks great Mike. I was wondering if it was big enough for two rear tires (which I would take irregaurdless if you change them or not). Are you also considering at least 1 spare front tire/wheel too? And I like the fact it is a well thought out design.
I hope this goes down, because I have been excited to see you out there on Drag Week with the Rampage.
Outcast Dodge guy.
[Re: dogdays]
#1599722
03/28/14 06:24 PM
03/28/14 06:24 PM
MR_P_BODY
R.
Normally on DW I/we never cook but it is a possibility at other times... I'll look into welding something up
[Re: 85_Ram_4speed]
#1599723
03/28/14 06:29 PM
03/28/14 06:29 PM
MR_P_BODY
I wont be going this year.. just too far to go .. but I can put in a set of front wheels and tire for racing.. I have pretty much a set of road racing tires on the front of the truck for the street.. they are a bit wide for the track but they handle real nice on the street
[Re: 340RICK]
#1599725
03/30/14 07:27 PM
03/30/14 07:27 PM
MR_P_BODY
Thanks guys.. it was a fun little project but was really needed if I wanted to carry anything.. just no room left after I got done with the truck... I still call it a truck but there is NO bed any longer
