Page 1 of 3 1 2 3
Power Cut Off switch Question. #1599655
03/28/14 02:20 PM
03/28/14 02:20 PM
Alberta, Canada
451Guy Offline OP
451Guy  Offline OP
Alberta, Canada
Last summer I finally got my car back to the track to make some passes. I had done a ton of stuff to it over the winter and one of the upgrades I made was installing an alternator for the first time. When I went through tech the inspector turned off the main power switch and the car kept running. I have since been told that I need to put a diode in the excite wire to solve this. I am getting ready to do this but I have no idea what size of diode I will require. The alternator is a 55 AMP Denso unit. Any input will be appreciated.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: Power Cut Off switch Question. [Re: 451Guy] #1599656
03/28/14 03:18 PM
03/28/14 03:18 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I used to run a switch on my alternator that I could control from inside the car.
Re: Power Cut Off switch Question. [Re: 451Guy] #1599657
03/28/14 03:37 PM
03/28/14 03:37 PM
Another option is to run the big battery charging wire from the alternator to the battery side of the switch so the alternator will charge the battery when the motor is running but it will not supply voltage to the electrical system when the cut off switch is turned off My car is that way, I used a #10 wire from the alternator ran directly to the battery + post connection
Re: Power Cut Off switch Question. [Re: Cab_Burge] #1599658
03/28/14 03:41 PM
03/28/14 03:41 PM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
Just put the disconnect on the ground cable
Re: Power Cut Off switch Question. [Re: challenger1320] #1599659
03/28/14 03:48 PM
03/28/14 03:48 PM
an8sec70cuda Offline
If I'm not mistaken, the NHRA and IHRA rulebooks both state the cutoff has to be on the positive side.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Power Cut Off switch Question. [Re: challenger1320] #1599660
03/28/14 03:50 PM
03/28/14 03:50 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Sorry, NHRA rules require the cutoff switch be in the positive cable, not negative. It would seem to work the same, if the wreck caused no body damage, but if it did and the negative cable was grounded before the switch by being cut the circuit would still be live and the switch would have no effect
I wanted to run it through the ground, too. It would have been easier, but you have to consider all possibilities or there is no point to doing it at all.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Power Cut Off switch Question. [Re: 451Guy] #1599661
03/28/14 04:15 PM
03/28/14 04:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The simplest way is to just run the alt output wire
to the battery side as Cab said.... there are other
ways to do it but thats the easiest and the best way
Re: Power Cut Off switch Question. [Re: Cab_Burge] #1599662
03/28/14 04:16 PM
03/28/14 04:16 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
thats how i did my dart, works good.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Power Cut Off switch Question. [Re: challenger1320] #1599663
03/28/14 04:22 PM
03/28/14 04:22 PM
The alternator will continue to supply voltage to the motor through the various engine to body grounds so shutting the switch off will not kill the supply of electrons to the ignition, trust me on that All electron flow from batterys is from the negative post through that cable to the to the motor and returns to the positive post of the battery, not from the positive to the negative like most people think That makes the negative cable not a good idea to hook up to the cut off switch
Re: Power Cut Off switch Question. [Re: Cab_Burge] #1599664
03/28/14 04:28 PM
03/28/14 04:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Wouldnt matter anyways... after you start the car you
can take the battery out and it'll run fine.. it has
to open the alt output circuit
Re: Power Cut Off switch Question. [Re: MR_P_BODY] #1599665
03/28/14 05:02 PM
03/28/14 05:02 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Most I know do what Cab says and run the alt output wire to the battery side of the cutout switch. Another option is like I did years ago on my bracket car and that was I put a toggle switch on one of the field wires and ran it inside the car so I could kill the charging system when I made a pass and you can also just kill the charging circuit when going thru tech with that toggle switch in the car so it dies when the kill (cutout) switch is turned off. It is alot less wire to run if you just tap into a field wire and run it in the car within the drivers reach on a toggle switch. I burned out a rotor on my bracket cars alt so thats one reason I would kill the charging system when making a pass. Ron
Re: Power Cut Off switch Question. [Re: 383man] #1599666
03/28/14 05:12 PM
03/28/14 05:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dont let the tech guy see you with a separate switch
set up like that... its a no no .. if you forgot and
had it on during a pass it wont kill the ignition
if needed and your knocked out
EDIT
I use to have a switch on the panel just to kill the
alt during a pass but I seen ZERO difference in et
or mph but that was with the output still on the
battery side of the switch... so when I rewired the
car I left that switch out of it
Re: Power Cut Off switch Question. [Re: MR_P_BODY] #1599667
03/28/14 05:22 PM
03/28/14 05:22 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run the alt output wire to the battery side of the cutout switch on my 63. I also put a voltmeter in the car since the stock ammeter wont read correctly when you run the alt output wire like that. On my old 340 bracket car in the late 70's and early 80's I burnt out two alt rotors so I thought taken power away from the rotor on the 6500 rpm passes may help to not damage the alt rotor circuit. Did it help ?? Well it did not burn out any more alt rotors but I did roll the car about 1-1/2 years later. Course with the alt output killed the car will die when the cutout switched is turned off even if the alt is not wired right but like you said if you forget to hit the toggle switch and would crash then it wont kill the car so I do agree with NHRA on that rule that you still have to run the alt output wire correctly. Ron
Re: Power Cut Off switch Question. [Re: 383man] #1599668
03/28/14 07:09 PM
03/28/14 07:09 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Does anyone have a fuse on their alt wire to the battery?
Re: Power Cut Off switch Question. [Re: rickraw] #1599669
03/28/14 07:28 PM
03/28/14 07:28 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I do.
If you like drag racing, support your local track.
Re: Power Cut Off switch Question. [Re: rickraw] #1599670
03/28/14 07:38 PM
03/28/14 07:38 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
I have one on the alt and the starter wire
Re: Power Cut Off switch Question. [Re: CHAPPER] #1599671
03/28/14 08:03 PM
03/28/14 08:03 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I do.
Lets go over this.... What size fuse, and where exactly is it?
Re: Power Cut Off switch Question. [Re: StealthWedge67] #1599672
03/28/14 08:30 PM
03/28/14 08:30 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
I have 150 and 300 amp
Re: Power Cut Off switch Question. [Re: StealthWedge67] #1599673
03/28/14 08:44 PM
03/28/14 08:44 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My original harness uses the fuseable links to protect the alt output wire from a short. I added a 70 amp large type bolt on fuse at the battery on my 63 with the battery in the trunk as it has eyelet terminals so I bolted it to the battery cable end and then bolted the wire from the alt to it as I put an eyelet terminal on the alt wire at the battery end. Ron
Re: Power Cut Off switch Question. [Re: 383man] #1599674
03/28/14 10:07 PM
03/28/14 10:07 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I don't like running the alternator wire to the battery because that wire will be hot all the time. I set mine up with a relay. I use a continuous duty relay, similar to a Ford starter relay. See attachment.
Page 1 of 3 1 2 3
