Re: blocked heater core.. what are you guys using????
[Re: Dakota_Don]
#159953
12/01/08 11:31 PM
12/01/08 11:31 PM
RapidRobert
I cupped a garden hose & back flushed one that was clogged & that took care of it in one minute. You have to regulate the flow as the garden hose has 60 psi
[Re: 1_WILD_RT]
#159955
12/02/08 11:48 AM
12/02/08 11:48 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Disconnect the heater hoses at the engine & use a garden hose to backflush it...I've done it a few times with great results...
[Re: kenworth_goose]
#159959
12/03/08 12:08 AM
12/03/08 12:08 AM
Posts: 18,422 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Remove heater hoses from engine, raise both hoses in the air, fill with vinegar, let it soak for a couple of hours, flush with lots of hot water, good to go.
I just read an article on that fix and its just as good if not better than most chemical flushes.
