Rear housing flange/brake #1599202
03/27/14 03:55 PM
03/27/14 03:55 PM
OH
Red383 Offline OP
Red383  Offline OP
OH
Can anyone give me a part # for this foam gasket/seal that goes between the axle flange and backing plate?
Is there a part # list somewhere for all the axle and brake parts and seals used when rebuilding the whole rearend?
Re: Rear housing flange/brake [Re: Red383] #1599203
03/27/14 05:06 PM
03/27/14 05:06 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
its in the factory parts section 5 brake service section 5-13-7 . the mopar foam gasket number is 2070933 or use a fel-pro 13800 or whoever else makes it. ronnie
Re: Rear housing flange/brake [Re: 1969ronnie] #1599204
03/27/14 05:12 PM
03/27/14 05:12 PM
1969ronnie Offline
1969ronnie  Offline
the picture of the foam gasket is shown in the wheels section number 22 but the part number is found in section 5-13-7. do you have a factory parts book for the year you are working on?
Re: Rear housing flange/brake [Re: Red383] #1599205
03/27/14 05:13 PM
03/27/14 05:13 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I just went through this with a friend with his '56 Plymouth project.
Locally, Pat Blais has an eBay store and supplies everything you would need. His store is T'Flite Patty's Shop Mart. I am sure there are others that can put together the same parts, too
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Rear housing flange/brake [Re: 1969ronnie] #1599206
03/27/14 06:21 PM
03/27/14 06:21 PM
OH
Red383 Offline OP
Red383  Offline OP
OH
Thanks. I have a Service manual for my car, but not a Factory parts book.
I figured there would be an online reference somewhere.
