Anyone using these rocker arms?
#1599186
03/27/14 03:54 PM
03/27/14 03:54 PM
Posts: 1,706 Nebraska
70VcodeCoronetRT
Nebraska
My guess is that they are junk. But I thought I would ask if anyone has seen or used these rockers before? http://www.ebay.com/itm/PRW-BB-Mopar-383...d6a&vxp=mtr Looking for a steel rocker for basically a mild 440. But I want a true 1.5 rocker ratio. Unlike the stamped rockers. Thanks
Re: Anyone using these rocker arms?
[Re: 70VcodeCoronetRT]
#1599190
03/27/14 04:39 PM
03/27/14 04:39 PM
Posts: 3,916 usa
lewtot184
usa
have you ever tried checking the rocker ratio on stamped rockers? from the testing i've done the low ratio stuff is more myth than fact. i don't buy in to it. i think a prominent vendor started this to get you to buy his stuff.
[Re: Mr.Yuck]
#1599193
03/27/14 07:38 PM
03/27/14 07:38 PM
Posts: 515 geezer acres rest home
dakotawilly
small print says we inspect for defects but small flaws are INEVITABLE.14 day money back guarantee,1 year warranty on parts,why accept any flaws?because Chinese parts are built strictly from stolen specs and infringed patents,copied using crap materials for profit.their idea of "runout" is when the cat gets away from the butcher block....I bet they would last a long time if you never started the motor.i know the hemi versions of these were horrible,the roller axles were loose after less than 2000 miles.please buy the good stuff!there are plenty of makers and plenty of used good rockers out there if you are on a budget.stop supporting the ti ni dong racing parts industry and they will dry up and blow away....
SFI 25.5 depends,no leak,even at 213 mph....
[Re: Thumperdart]
#1599196
03/28/14 01:11 AM
03/28/14 01:11 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
They look like the Pro-Comps I've been running for a few years with no issue. I would'nt pay THAT for them, though! For that sort of money, I'd go with a more reputable name. With that said, I've had good luck with these on my motor. I run a fairly tame, streetable solid cam. http://store.speedmaster79.com/p-3157-mo...set-shafts.aspx
[Re: dogdays]
#1599199
03/28/14 01:59 PM
03/28/14 01:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
So why is Mancini selling them if they're so bad? Just got a new Mancini flyer and there they were, PRW.
R.
Because people will buy them.. just because its Mancini it doesnt mean they have to be good quality parts.. what gets them a buck
[Re: Dean_Kuzluzski]
#1599200
03/28/14 02:27 PM
03/28/14 02:27 PM
Posts: 75,081 U.S.S.A.
JohnRR
U.S.S.A.
...............stop supporting the ti ni dong racing parts industry and they will dry up and blow away....
Buy these.......
http://chucker54.stores.yahoo.net/manciniracing21.html
They are budget made Harland Sharp rockers (roller tip, unbushed fulcrum). Whole package. American made.
Which ones , they have 2 different setups there , very confusing as to which are the sharps without the roller fulcrum ???
