400/4spd??? #1598951
03/27/14 12:02 AM
03/27/14 12:02 AM
Iowa
76dodgeboy Offline OP
Iowa
Ok. I've always heard they were Forged crank when factory 4spds. There's a guy saying his 77 bought new was not forged but cast. Did they have both than?
Re: 400/4spd??? [Re: 76dodgeboy] #1598952
03/27/14 01:48 AM
03/27/14 01:48 AM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
I have never seen a external balance Crank in a 400 or 440 with a Factory 4spd..The Autos where external but all the manual were internal to My knowledge. Ask him to look at the balancer
Re: 400/4spd??? [Re: Mpetros] #1598953
03/27/14 12:53 PM
03/27/14 12:53 PM
Iowa
Iowa
Well he's saying they never existed. Theres a guy selling a w300 400/4spd and says its forged and has the thin balancer. Balancer was mention it the post. It was on this site I read 400/4spds were forged
Re: 400/4spd??? [Re: 76dodgeboy] #1598954
03/27/14 12:55 PM
03/27/14 12:55 PM
Iowa
Iowa
Ive also heard there were never any 440 4spds from the factory but a few guys claim to have them
Id just like to further my knowledge on these trucks.
Re: 400/4spd??? [Re: 76dodgeboy] #1598955
03/27/14 01:13 PM
03/27/14 01:13 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I've never seen a cast BB crank that was drilled and reamed for a pilot bushing. I have seen one 440/4 spd truck and it was forged. I have seen 2 400/4spd combo's, one in a truck and one in a car. Both had forged cranks and are sitting in my parts garage somewhere.
Re: 400/4spd??? [Re: CTD5.9] #1598956
03/27/14 01:48 PM
03/27/14 01:48 PM
dogdays Offline
dogdays  Offline
Mopar, never say never!
R.
Re: 400/4spd??? [Re: dogdays] #1598957
03/27/14 03:22 PM
03/27/14 03:22 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
hah I know, I've never seen one but I'm sure they could exist. I have only looked at a small selection from Canada. Different plants could do different things etc. We had the same discussion on behind the seat tanks, it was hard to put a time on when they stopped putting them in.
Re: 400/4spd??? [Re: 76dodgeboy] #1598958
03/27/14 03:42 PM
03/27/14 03:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
This is the same argument that revolves around cranks, period; some swear there were no forged BB cranks after '76 regardless of transmission. If cast cranks were the rule of the day in '77 and '78 then it follows that stick shift vehicles would have cast cranks in those years.
Re: 400/4spd??? [Re: John_Kunkel] #1598959
03/27/14 06:44 PM
03/27/14 06:44 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
A parts book should confirm that Forged were indeed standard with a manual trans. I don't think there was a flywheel available for a cast 400 or 440, no flywheel means they couldn't have made them.
Sheldon
Re: 400/4spd??? [Re: RUNCHARGER] #1598960
03/27/14 07:37 PM
03/27/14 07:37 PM
Iowa
Iowa
The one guy says his is cast and the part number was different for His 400. There's another guy saying the balancers were different for different years so a thin balancers could still be cast crank
Re: 400/4spd??? [Re: 76dodgeboy] #1598961
03/28/14 12:03 AM
03/28/14 12:03 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I saw one once stories... with out pics its BS
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 400/4spd??? [Re: 76dodgeboy] #1598962
03/28/14 12:12 AM
03/28/14 12:12 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
You all realize we are talking about a time period where Chrysler was facing financial hardship, and all big block production was coming towards an end, right? I suspect Mopar was raiding every nook and cranny to use up anything that may have been hiding on some shelf someplace. Really, how many big block, stick, trucks were produced in 77 & 78? Would have been easier to send someone off to the machine shop with a flywheel to get specially cut, then to make a run of special flywheels for a limited number of trucks. There were a lot of inconsistencies at Mopar between 76 & 78, covering a whole range of things. It was a sign of the times. Gene
Re: 400/4spd??? [Re: 76dodgeboy] #1598963
03/28/14 07:06 AM
03/28/14 07:06 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
The cranks are cast originally. I have a 440/4spd truck, when I bought the 77 440 core from the original owner, it had the original flywheel with the 3 big balancing holes drilled in the back for the external balance and was also drilled for the pilot bushing.. The flywheel was unusable, bought another from Brewers 4spd parts. The donor parts truck was missing its 4spd bellhousing, so I found another guy wrecking a 78 400/4sp truck and bought his bellhousing. His 400 engine had the same flywheel.
The only truck big block I ever saw with a forged crank was a 413 my friend bought from from some late 60's truck.
Re: 400/4spd??? [Re: Uberpube] #1598964
03/28/14 08:16 AM
03/28/14 08:16 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Can't count how many BB 4-spd trucks I've had and all were forged cranks all the way through 78.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 400/4spd??? [Re: moparmarks] #1598965
03/28/14 09:02 AM
03/28/14 09:02 AM
moparmarks Offline
moparmarks  Offline
Now I did come across a 1978 440 industrial water pump. It had a cast crank with this 173T wheel balanced for the cast crank. It was direct drive with no clutch.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 400/4spd??? [Re: moparmarks] #1598966
03/28/14 12:02 PM
03/28/14 12:02 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
FWIW I have had 2 different 78 truck steel crank 440's w/std trans. Both were neutral balance with heavy (6pk) rods.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: 400/4spd??? [Re: 64dodge572] #1598967
03/28/14 01:45 PM
03/28/14 01:45 PM
Freeport IL USA
Freeport IL USA
Sounds like the big block with 4 speed was a mixed bag. It would be interesting to determine if the cast crank 4 speed trucks were early trucks or late trucks. Might be such a thing that Mopar originally thought the cast crank was up to the job and discovered differently, or that the original plan was to use up the forged cranks remaining in inventory until they ran out, then hope the cast cranks were up to the task. I suppose a 3rd option was they started with the cast cranks, were somewhat disappointed with their service life and went to existing inventory until they ran out, then went back to the cast cranks as a last resort.
The possibility still exists that they grabbed whatever was handy on the production line as well. Two things are fairly obvious, nothing was consistent, and what the books say they did is not very accurate. Gene
Re: 400/4spd??? [Re: poorboy] #1598968
03/29/14 01:41 PM
03/29/14 01:41 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
http://paintref.com/cgi-bin/brochuredisp...=13&scan=13
The only restriction I can see for engine/tranny combos is for California emissions.
I am of thinking that if truck engines were forged cranks in the mid to late 70's, every dodge truck would have been plundered for its big block by all the drag racers before the advent of cheap aftermarket cranks.
Re: 400/4spd??? [Re: 76dodgeboy] #1598969
03/31/14 10:08 AM
03/31/14 10:08 AM
southeast, mich
MachoMan Offline
MachoMan  Offline
southeast, mich
I have 2 documented. Both are 75 W200 clubcabs.
Have had several other claims but no paperwork that could back them up.
Never say never
Please register your Dodge truck here 1972-1980 Dodge truck registry
Re: 400/4spd??? [Re: MachoMan] #1598970
03/31/14 11:04 PM
03/31/14 11:04 PM
Iowa
Iowa
Just telling what I was told. Believe it was on here or RCC that I saw it too.
