Brake Booster Hose under or over linkage? #1598839
03/26/14 06:57 PM
03/26/14 06:57 PM
Phoenix, AZ
MCTPhoenix Offline OP
Phoenix, AZ
'69 Charger with 440 and pdb. The vacuum hose for the booster looks like it could run under the throttle bracket but then it would turn up and have to make a sharp 180 deg bend to slip down on the vacuum port on the manifold.. looks very tight. Is this the correct path or should it just pass over the throttle linkage? Thanks again everyone... Mike
Re: Brake Booster Hose under or over linkage? [Re: MCTPhoenix] #1598840
03/26/14 07:26 PM
03/26/14 07:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
69 I'm pretty sure it was over , when they went to the one piece linkage there was a loop on the back of the throttle bracket that the hose passed thru.
Re: Brake Booster Hose under or over linkage? [Re: JohnRR] #1598841
03/26/14 09:20 PM
03/26/14 09:20 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Yep sharp loop out from under the bracket to the hose fitting.
Ron
Re: Brake Booster Hose under or over linkage? [Re: RJS] #1598842
03/26/14 09:22 PM
03/26/14 09:22 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
again
Re: Brake Booster Hose under or over linkage? [Re: RJS] #1598843
03/26/14 09:58 PM
03/26/14 09:58 PM
Phoenix, AZ
Phoenix, AZ
4speed car.. I'll have to see if my throttle linkage is the same
Re: Brake Booster Hose under or over linkage? [Re: MCTPhoenix] #1598844
03/26/14 10:09 PM
03/26/14 10:09 PM
My 383 4 bbl 4 spd car is exactly the same as RJS
Re: Brake Booster Hose under or over linkage? [Re: ] #1598845
03/26/14 10:11 PM
03/26/14 10:11 PM
slightly different angle.
