Any way to soften up an old windshield gasket? #1598506
03/26/14 02:16 AM
03/26/14 02:16 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
Just curious, I got an old 69 B body windshield gasket, it's not rock hard but not like a fresh gasket either. Is there anyway to soften it up, maybe by soaking it in something that softens rubber.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Any way to soften up an old windshield gasket? [Re: AZ_A12_BEE] #1598507
03/26/14 02:17 AM
03/26/14 02:17 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Vaseline softens them up.
Sheldon
Re: Any way to soften up an old windshield gasket? [Re: RUNCHARGER] #1598508
03/26/14 02:19 AM
03/26/14 02:19 AM
Dreaming of the 808
Dreaming of the 808
Sheldon
Do you rub it in and let it soak in?
Re: Any way to soften up an old windshield gasket? [Re: AZ_A12_BEE] #1598509
03/26/14 02:38 AM
03/26/14 02:38 AM
RUNCHARGER Offline
RUNCHARGER  Offline
Rub it in a few times to soften it up. I haven't tried it for 20 years but it used to work. The gaskets are older now of course.
Sheldon
Re: Any way to soften up an old windshield gasket? [Re: RUNCHARGER] #1598510
03/26/14 03:26 AM
03/26/14 03:26 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Dave i hear a couple ounces of wintergreen oil in a pint or so of xylene. The wintergreen is supposed to have a natural plasticizers called meythyl salicylate. I have never tried it myself but this is what the chemist said at the rubber manufacturer i work at.
Re: Any way to soften up an old windshield gasket? [Re: AZ_A12_BEE] #1598511
03/26/14 03:40 AM
03/26/14 03:40 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I will suggest silicone, not any lube that has petroleum in it.
Rubber hardens due to exposure to sun (and petroleum products over time). In it's natural state rubber is white (as why old tires were white). anyone remember those movies in school of the natives pouring latex and rolling big donut wheels of rubber?
the black comes from carbon black added to uv protect the rubber from oxidizing. it still will over time but silicone is the by-product of rubber oxidizing. wind dirt and ran carries it away, the silicone protects and rejuvenates to top few layers.
best thing for protecting it is 100% silicone grease. permatex dielectric grease was one source, dow 33 another but I'd make sure it did not go syn.
smear it on, let it set a day or so then wipe off. repeat occasionally.
Re: Any way to soften up an old windshield gasket? [Re: srt] #1598512
04/03/14 12:34 AM
04/03/14 12:34 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
If you mean for installation,we once took the gasket for an 84 pickup,threw it in a pot of water on the stove for a bit,and installation was a snap. It was cold as all hell out,and otherwise I doubt we would have successfully installed it.
Re: Any way to soften up an old windshield gasket? [Re: AZ_A12_BEE] #1598513
04/03/14 08:04 PM
04/03/14 08:04 PM
canada
rumrunner Offline
rumrunner  Offline
canada
Palmolive soap and warm water.
Re: Any way to soften up an old windshield gasket? [Re: rumrunner] #1598514
04/04/14 01:03 AM
04/04/14 01:03 AM
south central nebraska
GI Moparman Offline
GI Moparman  Offline
I was looking for a new gasket for my convertable a couple years ago when they were back ordered and one of the dealers at mopars in the park told me if gasket was in good shape and not torn, to run it through the dish washer. He said the heat and steam will soften it up. Never tried it cuz I ended up with a new one before I got that far.
Re: Any way to soften up an old windshield gasket? [Re: AZ_A12_BEE] #1598515
04/22/14 12:41 PM
04/22/14 12:41 PM
Phoenix, AZ
MCTPhoenix Offline
MCTPhoenix  Offline
Phoenix, AZ
was told years ago by some old-timers in the 300 Club to thoroughly clean the gasket then soak it in handcleaner like goop for a week. Seemed to work
Re: Any way to soften up an old windshield gasket? [Re: MCTPhoenix] #1598516
04/22/14 06:42 PM
04/22/14 06:42 PM
Valley of the sun, AZ
2
2JcodeChargers Offline
Dave,
I'll second Mike's suggestion on the Goop handcleaner. Sounds goofy, but it works.
Chris
Re: Any way to soften up an old windshield gasket? [Re: 2JcodeChargers] #1598517
04/22/14 10:41 PM
04/22/14 10:41 PM
South Lyon MI
sleddinfool Offline
sleddinfool  Offline
South Lyon MI
A guy I work with just softened some 1966 motorcycle carb boots up with the same thing ademon suggested with the xylene and wintergreen?.. It worked well...Kevin
71 gtx.....
