3" .083 DOM driveshaft #1598234
03/25/14 11:08 AM
03/25/14 11:08 AM
Az
HOT IN AZ Offline OP
Az
Needing a driveshaft built and local driveline supplier suggested a driveline made out of 3" .083 DOM material. Diameter seems a little small to me but I see other major suppliers making them out of the same material. Car will have less than 500hp and weigh in the 3400lb area. Any suggestions/comments greatly appreciated!
Re: 3" .083 DOM driveshaft [Re: HOT IN AZ] #1598235
03/25/14 11:17 AM
03/25/14 11:17 AM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
I have used Precision Driveline
http://precisiondrivelines.com/
And Dick's Driveshaft
http://www.dicksdriveshaftphoenix.com/?gclid=CMy-r8_irb0CFQZU4godfHsAxg
Both are in Phoenix and are very good.
Re: 3" .083 DOM driveshaft [Re: HOT IN AZ] #1598236
03/25/14 11:22 AM
03/25/14 11:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
With less than 500hp it should be fine... but the
length is one of the important factors also... but
being a shop that builds the shafts they should know..
I have a 3.5" DOM shaft on both the race car and my Rampage
Re: 3" .083 DOM driveshaft [Re: HOT IN AZ] #1598237
03/25/14 11:28 AM
03/25/14 11:28 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Don't forget Dr Diff.
Master, again and still
Re: 3" .083 DOM driveshaft [Re: HOT IN AZ] #1598238
03/25/14 12:42 PM
03/25/14 12:42 PM
Az
Crizila Offline
Crizila  Offline
Az
I used "Arizona Driveshaft" (480) 898-0829. Had mine made from 3.5" .083 DOM. My shaft was something like 43" long. You could probably get away with 3" at that HP level.
Fastest 300
Re: 3" .083 DOM driveshaft [Re: Crizila] #1598239
03/25/14 02:28 PM
03/25/14 02:28 PM
dogdays Offline
dogdays  Offline
The rpm the driveshaft sees, the diameter, thickness and unsupported length are very important. You do not want the driveshaft operating near the first harmonic.
R.
