QA1 K member in 1965 Dodge Coronet #1598166
03/25/14 02:41 AM
03/25/14 02:41 AM
washington
Bruce Offline OP
Bruce  Offline OP
washington
Any one have any information on using one of their K members in a 65 b body?
Looking on the web it seems you can use the 1966 and up b body k member, but it sets the engine back 1" to 1& 3/4". I don't want the transmission hitting the tranny tunnel. If this isn't a good swap does any one know of a tubular k member that is made to this car.
I just bought the car a month or so ago and pulled the engine and tranny to do a rebuild of the front end, engine and transmission. I noticed the motor mounts were something some one made up to put the engine in using a slant 6 k member.
Any way any help would be appreciated.
Thanks,
Bruce
Re: QA1 K member in 1965 Dodge Coronet [Re: Bruce] #1598167
03/31/14 03:05 AM
03/31/14 03:05 AM
washington
Bruce Offline OP
Bruce  Offline OP
washington
Ordered a QA1ck frame, so we will see how that goes.
Re: QA1 K member in 1965 Dodge Coronet [Re: Bruce] #1598168
03/31/14 10:15 AM
03/31/14 10:15 AM
Wildwood, FL
1fastabody Offline
1fastabody  Offline
Wildwood, FL
Here is what you have been asking about, I knew I seen it I just couldn't find it till now.
http://www.forbbodiesonly.com/moparforum...n-steering-gear
Re: QA1 K member in 1965 Dodge Coronet [Re: 1fastabody] #1598169
04/02/14 12:29 AM
04/02/14 12:29 AM
washington
Bruce Offline OP
Bruce  Offline OP
washington
I saw that car on the B Body only. Beautiful car.
