Revised! SIX PACK carb numbers. Need decoded.
#1598042
03/24/14 09:24 PM
03/24/14 09:24 PM
Posts: 1,562 Manistee, Michigan.
High Impact
Manistee, Michigan.
Im getting things ready for my 70 Road Runner project and have had this six pack intake set-up for a couple years now and I need some help figuring out what I have. The front carb has either a driffent float bowl or its the wrong carb all together?? Okay, so I RE-LOOKED AT THE NUMBERS TODAY> Rear carb-1219 LIST 4394 Center -0919 LIST 4391 Front -1139 LIST 4393 I was told that it came off a A-12 car that was wrecked back in 1971-72 and sitting in a detroit junkyard and that the guy bought it and stuck it on his new 1972 GTX (440-4sp-dana) and thats where it remained till I bought the car a few years ago and took the intake off and put it upstairs in the garage, Now I want to figure out what I have and get it all re-done! Thanks for any help.
Re: SIX PACK carb numbers. Need decoded.
[Re: High Impact]
#1598047
03/24/14 09:44 PM
03/24/14 09:44 PM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
Rear carb-12-19 LIST 4394 = 1969 Outboard Center -09-18 LIST 4391 = 1969 4-sp Manual Center Front -11-37 LIST 4398 = ? Are you sure on the 4398? I don't have anything for that one. There should be date codes as well......................
Admiration For Multiple Carburetor Vehicles...
[Re: High Impact]
#1598048
03/24/14 09:47 PM
03/24/14 09:47 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
According to the Holley Specs manual
4394 would be the correct rear for both auto and manual 4391 would be the correct center for a manual tranny 4398 doesn't exist. Most likely it is 4393 which is the correct front for auto and manual
Fuel bowl likely has been replaced in the past.
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: RealWing]
#1598049
03/24/14 09:58 PM
03/24/14 09:58 PM
High Impact
Manistee, Michigan.
Where are the date code's at? I thought the 1219,0918, and 1137 other numbers like that were the date codes.
