Torque converter weights. #1598010
03/24/14 08:03 PM
03/24/14 08:03 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
if i weld the weights for my cast crank on a neutral balance torque converter is there anything to consider "heat wise"
just ground at the ring gear to avoid current flow through anything but the case?
Re: Torque converter weights. [Re: can.al] #1598011
03/24/14 10:51 PM
03/24/14 10:51 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
weld away with a good weld in the hole unless its a lockup converter.
I am truckless..
Re: Torque converter weights. [Re: 340SHORTY] #1598012
03/25/14 03:47 PM
03/25/14 03:47 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..anybody know what the weights weigh in grams on a cast crank 340 torque converter?
Re: Torque converter weights. [Re: can.al] #1598013
03/28/14 01:39 PM
03/28/14 01:39 PM
Brodheadsville Pa.
franko Offline
franko  Offline
Brodheadsville Pa.
Two 25 gram weights.if you need the location of the weights I can send info.
