good transmission mount for my 84 D150 #1597840
03/24/14 02:15 PM
03/24/14 02:15 PM
Crockett ,TX
9
98RAM1500 Offline OP
Crockett ,TX
is this the poly version of the truck transmission mount?
http://chucker54.stores.yahoo.net/malamocopomo.html
Re: good transmission mount for my 84 D150 [Re: 98RAM1500] #1597841
03/24/14 07:28 PM
03/24/14 07:28 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
IMHO I would use a urethane insert from PST they only made almost 20 versions of the mount you linked from Chrysler originally
there's different offsets The PST version you reuse the original steel parts
Most of the time when I replace using urethane bushings I take a piece of threaded rod,some nuts & some thick flat washers & press the ears apart where the usually wider urethane bushing doesn't want to fit
Re: good transmission mount for my 84 D150 [Re: BulletBob] #1597842
03/24/14 10:44 PM
03/24/14 10:44 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Thats the correct style. I used the Energy Suspension bushing. Its a lot cheaper than the Mancini version.
I am truckless..
Re: good transmission mount for my 84 D150 [Re: 340SHORTY] #1597843
03/25/14 12:09 AM
03/25/14 12:09 AM
Crockett ,TX
9
Crockett ,TX
yeah I just got through checking energy's site out probably what my plan will be thanks for the help
Re: good transmission mount for my 84 D150 [Re: 98RAM1500] #1597844
03/25/14 01:05 AM
03/25/14 01:05 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
FYI those mounts are tapered as is the metal insert in the mount. They go in 1 way.
I am truckless..
