A Body Cuda Taillight Gaskets
#1597810
03/24/14 01:55 PM
03/24/14 01:55 PM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
I installed the taillights on the cuda this past weekend, and the new gaskets I have a WAY too thick - almost 1/4".
Does anyone make a correct thickness gasket for the 'cuda taillights? The ones I have were from PG Classics.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: A Body Cuda Taillight Gaskets
[Re: Erik]
#1597811
03/24/14 02:37 PM
03/24/14 02:37 PM
Posts: 2,502 Shelby, Ohio
2abodymcodes
Shelby, Ohio
If 69 gaskets are the same, i've got an extra set i'll give you. just pay the stamp. they are from DMT and fit real nice.
[Re: 2abodymcodes]
#1597812
03/24/14 02:52 PM
03/24/14 02:52 PM
Erik
Stroudsburg, PA
They look to be the same. How thick are your gaskets?
[Re: 2abodymcodes]
#1597813
03/24/14 02:59 PM
03/24/14 02:59 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
The large fairly complex molded rubber gaskets than fit between the t/l housing and the rear quarter panel? I didn't think DMT had the capability to make molded gaskets in house.
Eric, was there any rear quarter work done to your Cuda? Could there be any excess skim bondo in the recease of the tail light bucket. Faint chance, but asking just in case.
[Re: autoxcuda]
#1597814
03/24/14 03:47 PM
03/24/14 03:47 PM
Erik
Stroudsburg, PA
Yes - the gasket between the 1/4 and the housing. The housings are new, so there is no Bondo on them. With the 1/4" gaskets I have now, they sit way to far out and look silly sticking out from the trunk mouldings.
[Re: Erik]
#1597815
03/24/14 03:56 PM
03/24/14 03:56 PM
autoxcuda
So Cal
I was thinking bondo or repro panel or bodywork on the body as opposed to the housing.
If it's the same gap on both sides, its most likely a gasket/housing issue.
Do you have your old gaskets?
[Re: autoxcuda]
#1597816
03/24/14 04:11 PM
03/24/14 04:11 PM
Erik
Stroudsburg, PA
I wish I had them. Then I would not have this issue. I thought about pulling them off the old housings before I sold them, and never did. My bad.
