95 intrepid intermittent overheating problem #159770
12/01/08 07:54 PM
12/01/08 07:54 PM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
my mother-in-law has a 95 intrepid and for some reason today it had fits with overheating. i'm finding no water in the oil, no white smoke out of the exhaust, the fans switch on and off. everything seems to be working fine. she said this has happened 3 or 4 times now. the first guy replaced the thermostat. this is the 3.5L engine.
also does anyone know where the water pump on this? is it timing belt driven? the car has about 130,000 on it and has never had a timing belt or water pump replaced. oil is changed regularly by me.
any ideas are greatly appreciated. btw i'm getting codes 117, 118, 171. i know 171 is an O2 sensor. and i know 117 and 118 are related to the temp sensor. i am getting 5V at the sensor connector as well as a good ground. i still do suspect the sensor of being faulty but i don't know if it can be intermittent like this.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 95 intrepid intermittent overheating problem [Re: Jerry] #159771
12/01/08 08:23 PM
12/01/08 08:23 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
I.m guessing you have cylinder head gasket leaking.
The pump is deep in behind the timing cover . You have to remove rad , crank pulley and a host of parts, belt , tensioner, its the most poorly built engine i've seen .
My opinion ...................its a piece of chit.
some diff then the little 3.3 that were in the Dynasty's
Good Luck , bet you will have to tear it down again in no time.
Re: 95 intrepid intermittent overheating problem [Re: mopar_man] #159772
12/01/08 10:13 PM
12/01/08 10:13 PM
Pennsylvania
cantspel Offline
cantspel  Offline
Pennsylvania
One of the best engines we have. Timing belt/water pump is easily done by an experianced tech in 45 min. You don't indicate whether the engine actually overheats, or the gauge just says so. But I can tell you that I've fixed more than one blown head gasket on those engines with a radiator cap that won't hold pressure. Test the cap first.
Re: 95 intrepid intermittent overheating problem [Re: cantspel] #159773
12/02/08 12:06 PM
12/02/08 12:06 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It is a completely sealed and pressurized cooling system AND it doesn't like air pockets. At 130,000 it NEEDS a timing belt and water pump at the very least. Also, as good as the 3.5 is they are not very forgiving to overheating. Very stout motor otherwise.
There's lots of things I don't like about the LH cars, but the 3.5 is not one of them.
Re: 95 intrepid intermittent overheating problem [Re: Jim_Lusk] #159774
12/02/08 10:23 PM
12/02/08 10:23 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Great forum here: http://www.dodgeintrepid.net/forums/
I signed up when I bought my '94 Intrespid (3.3l)
Re: 95 intrepid intermittent overheating problem [Re: In_The_Pink] #159775
12/02/08 11:49 PM
12/02/08 11:49 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
3.5 is an AWESOME engine!! I agree, t-belt should have been done at around 90K, and you might as well do a h20 pump while you're in there, and possibly a tensioner pulley. I'm also betting that you are probably due for a radiator. There is also a module on the fan that would sometimes cause issues of one or no fans working (RFI module).
Re: 95 intrepid intermittent overheating problem [Re: In_The_Pink] #159776
12/02/08 11:53 PM
12/02/08 11:53 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Check to see if the rad. fan comes on, a bad radiator fan relay could be your problem. 3.5L w/pump and timing belt as stated above are fairly easy to do. 3.5L was one of the better engine made at the time imo
Re: 95 intrepid intermittent overheating problem [Re: SALEM1912] #159777
12/02/08 11:59 PM
12/02/08 11:59 PM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
thanks for the ideas... the fans turn on when i disconnect the temp sensor. with my scan tool it looks like the sensor is in the right range for operation. so that brings me back to the water pump/ timing belt.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: 95 intrepid intermittent overheating problem [Re: Jerry] #159778
12/03/08 12:05 AM
12/03/08 12:05 AM
N
NITROUSN Offline
NITROUSN  Offline
N
You need to verify the fan runs off the sensor correctly. Unplugging it means it can run. Seeing it is in operating range is fine but will the sensor change enough to switch the fan on????
Re: 95 intrepid intermittent overheating problem [Re: NITROUSN] #159779
12/03/08 12:07 AM
12/03/08 12:07 AM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
the fans also seem to kick on at about 230°F and then off around 210. i don't know what the actual on off temps are supposed to be but thats what my scan tool reads. when i hear the fans kick on and off.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: 95 intrepid intermittent overheating problem [Re: Jerry] #159780
12/03/08 12:10 AM
12/03/08 12:10 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Sounds ballpark. Seems like the older k-cars were 205 but most gm cars are in the 230 range.
Re: 95 intrepid intermittent overheating problem [Re: NITROUSN] #159781
12/03/08 12:26 AM
12/03/08 12:26 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Yes those temps are in the ballpark as Nitrousn said above. you may have a w/pump with some rusted off impellers.Esp if your coolant was rusty.
Re: 95 intrepid intermittent overheating problem [Re: SALEM1912] #159782
12/03/08 11:11 PM
12/03/08 11:11 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Our shop has fixed many of them by replacing the head gaskets and checking the heads for warpage. Ron
Re: 95 intrepid intermittent overheating problem [Re: 383man] #159783
12/04/08 12:16 AM
12/04/08 12:16 AM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
if the heads were warped and the head gasket blown, wouldn't i see milky oil or steam coming out of the exhaust?
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: 95 intrepid intermittent overheating problem [Re: Jerry] #159784
12/05/08 03:13 AM
12/05/08 03:13 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You would think so but no it does not show them condition's. It almost acts like its not a head gasket problem. What happens is the fan comes on and stays on as it wont get cool enough to turn the fans off at idle. It will idle and come down to about 220 to 230 but just not cool enough to turn the fans off. And it will boil coolant out of the overflow bottle sometims and even start to melt the overflow bottle. It seems to push combustion pressure into the cooling system causing hot air pockets. Ron
Re: 95 intrepid intermittent overheating problem [Re: 383man] #159785
12/05/08 01:05 PM
12/05/08 01:05 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
You never said that you were actually losing coolant. Also, get a temp gun and get a reading from the coolant. It may be just a bad sender/ gauge. Also, maybe pull the radiator and use a garden hose and flush the exterior of the radiator from the engine side. Many cars have heating problems because debris gets caught in front of the condenser and radiator.
Re: 95 intrepid intermittent overheating problem [Re: Jerry] #159786
12/05/08 01:27 PM
12/05/08 01:27 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I have 4 1st gen intrepids, 2-3.3L and 2 3.5L. I disagree with the earlier poster who says the 3.5 is junk. Its a good motor that makes good power.
In my opinion you should always take care of the known issues first and the waterpump and timing belt are overdue. Change those and my guess is your overheating problem will go away. I've done both mine 3.5s now. I think the second one took me a couple hours to do. You can borrow the balancer tool from an autozone. Remove the brace accross the radiator and the fans and then you can remove the belt covers and radiator hoses. Pull the old pump and take it with you to the parts store, there are to pump versions availiable 3 and 6 bolt. Total is under $100.00
Ken
