PPG Deltron Paint? ANYONE ever use it?? Good/Bad #1597701
03/24/14 12:25 PM
03/24/14 12:25 PM
Manistee, Michigan.
High Impact Offline OP
Manistee, Michigan.
I went to our local paint supplier again and they finally found a code for F4 to re-paint my 70 Runner. ITs Dupont Chroma Base and only $407.00 dollars a gallon!! HOLY CRAP!
So I check with a PPG supplier out in New York and they say they can mix it in a PPG Deltron Urathane for 176.86 a gallon! BIG DIFFRENCE!
Has anyone used PPG and is the deltron series a comparable product to Chroma Base?
Re: PPG Deltron Paint? ANYONE ever use it?? Good/Bad [Re: High Impact] #1597702
03/24/14 12:38 PM
03/24/14 12:38 PM
So. Illinois
bronze69 Offline
bronze69  Offline
So. Illinois
Be careful, 176.86 sounds awful cheap. I just priced a gallon of R4 Deltron basecoat and was told about the same price, but when I asked he said that was Omni basecoat.(Omni is PPG's cheap line) When I told him to give me a price for PPG Deltron, it was $470 a gallon.
$400-500 a gallon is about normal anymore for a high end Urethane.
Re: PPG Deltron Paint? ANYONE ever use it?? Good/Bad [Re: bronze69] #1597703
03/24/14 01:16 PM
03/24/14 01:16 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I had a local paint store jockey try to talk me into the Omni line a few years ago, "everybody uses it" "it's the same stuff" I responded with I'm not everybody and I want the paint to last
And to answer the original question I put Deltron on my Charger 20 years ago, No problems yet
Re: PPG Deltron Paint? ANYONE ever use it?? Good/Bad [Re: High Impact] #1597704
03/24/14 06:13 PM
03/24/14 06:13 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Try House of Kolor. Not just Kosmic but any color
you want they can mix.
Snap your neck, mega G-force launch, is all I want!
Re: PPG Deltron Paint? ANYONE ever use it?? Good/Bad [Re: BDS871Cuda] #1597705
03/24/14 09:01 PM
03/24/14 09:01 PM
Detroit, MI
GetAwayDriver Offline
Detroit, MI
Just to answer your question, I've used PPG Deltron for 20-years and it's very good stuff.
Re: PPG Deltron Paint? ANYONE ever use it?? Good/Bad [Re: GetAwayDriver] #1597706
03/24/14 09:07 PM
03/24/14 09:07 PM
Manistee, Michigan.
Manistee, Michigan.
So, when the guy told me it was PPG DELTRON it "could be" Omni brand? Is there such a thing as Omni Deltron?
I've heard of Omni, is it comparable to Nason in Dupont.....Kind of a thin watery paint.
Re: PPG Deltron Paint? ANYONE ever use it?? Good/Bad [Re: High Impact] #1597707
03/24/14 09:18 PM
03/24/14 09:18 PM
Detroit, MI
Detroit, MI
He's being dishonest if he's mixing the terminology. Deltron is Deltron and Omni is Omni, the only common part is PPG makes both of them. It would be like saying "I used to own a Hemi 318"... Chrysler terminology, but different engines.
I could picture somebody trying to pull that, and the low price sounds like lower-end paint.
Just to mention it, I sprayed Nason urethane a few years back and although I was rather concerned with how watery it looked, it turned out quite well, and held its shine for all the time I owned it. Of course, this was a simple, white single-stage paint job.
Re: PPG Deltron Paint? ANYONE ever use it?? Good/Bad [Re: GetAwayDriver] #1597708
03/24/14 11:35 PM
03/24/14 11:35 PM
Washington PA
69 plymouth rnr Offline
Washington PA
Ok again here is my PPG name covers ppg deltron dbc ,envirobase ehp,deltron dbu ,omni and omni plus. The omni base coat is cheaper because its thinner and will require more coats witch = more time and labor cost depending on the color. omni mtk is the single stage witch is ok for the money . plus is the best bang for the buck for base coat and spend the x tra on the clear its what protects the color . as far as "dupont" goes they were sold and now called XALTA..... they are dumping people and raising prices to pay investors back your choice
Re: PPG Deltron Paint? ANYONE ever use it?? Good/Bad [Re: 69 plymouth rnr] #1597709
03/24/14 11:54 PM
03/24/14 11:54 PM
Kirkland, Washington
Pacnorthcuda Offline
True, but the new owners of DuPont's paint line is "Axalta".
Re: PPG Deltron Paint? ANYONE ever use it?? Good/Bad [Re: Pacnorthcuda] #1597710
03/25/14 12:03 AM
03/25/14 12:03 AM
IN
ahy Offline
ahy  Offline
IN
If you are looking for a classic paint match I suggest "autocolorlibrary.com". They have PPG paint as well as their "restoration shop" house brand. I have had good luck with both. PPG Plum Crazy base clear for my classic and house brand for several DD's.
I have used Omni base/clear also. It worked OK but coverage was less than spectacular.
Re: PPG Deltron Paint? ANYONE ever use it?? Good/Bad [Re: ahy] #1597711
03/25/14 02:30 AM
03/25/14 02:30 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Some colors in Omni are Ok, but anything with "poly" in the original name is going to be trouble.
I just painted this 69 Charger in Omni, I looked terrible with poor coverage, and light/ dark areas everywhere. After 4 coats of color..
the paint was transparent like water...
Had to reapray the car with DBU base and clear.. wound up costing a ton more for materials, not to mention the labor and delay in getting it done...NO more Omni for me..
Re: PPG Deltron Paint? ANYONE ever use it?? Good/Bad [Re: High Impact] #1597712
03/25/14 09:45 AM
03/25/14 09:45 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
I use Shop line from PPG on the 1972 Charger in Detonator Yellow over a gray primer. Had to buy an extra gallon for full coverage.
The Shop Line Sublime I painted on the 1974 Satellite covered nice in two coats.
Always shoot 3 coats of clear and sand it flat. I have no problems. Charger has been painted 4 yrs and still looks good.
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: PPG Deltron Paint? ANYONE ever use it?? Good/Bad [Re: 70Coronet500Vert] #1597713
03/25/14 12:02 PM
03/25/14 12:02 PM
parma,ohio
66littlebigmopar Offline
parma,ohio
The difference between the omni and chronabase is you will have better color match with the chromabase than the omni. The omni isn't thinner it uses fewer pigments to make the color thats what makes it need more coats for coverage. The chromabase will get you a truer color.
Re: PPG Deltron Paint? ANYONE ever use it?? Good/Bad [Re: 66littlebigmopar] #1597714
03/25/14 04:11 PM
03/25/14 04:11 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Actually my local paint supplier doesn't have the colors to mix a lot of the old colors in chromabase but can do it in nason.
Also to the original poster, remember chromabase is mixed 1 to 1. So you probably don't need a gallon unless your doing the whole car, inside and out. I've resprayed car with a quart that were just repaints.
I use a lot of the nason and I've had great results with the color matching on newer cars. Older cars, it's usually close. Also the nason clear is really good clear for the price, I use it almost on everything.
As far as the delton, highly doubt your getting a gallon of it for under 200. I don't use much ppg anymore, closest place, the prices are insane.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
