Installing New Kenwood Radio
#1597425
03/23/14 04:54 PM
03/23/14 04:54 PM
Posts: 1,032 Ohio
dobie
Ohio
So on a whim I picked up a new radio for my RR. My factory radio has never worked as far as I know, and there are no speakers in the car. During a trip to Best Buy I bought this: kenwood I also got a pair of 6x9's for the package tray. For now, I have no plans on front speakers. Has anyone installed this particular radio or something similar? Of course there is no "install" kit available from Kenwood. I do not want to cut up my dash at all. I already have a radio plate, but I have no clue what else I need. How did you guys get these radios secured to the dash? What kind of fabrication is there? Any thoughts on the speakers as well? Like I said, for now I only have a pair of 6x9's for the rear. I dont expect absolute perfect sound quality....Just something decent to listen to while cruising down the road. Thanks.
1968 Plymouth Road Runner
383 4 speed
Re: Installing New Kenwood Radio
[Re: dobie]
#1597426
03/23/14 06:54 PM
03/23/14 06:54 PM
Posts: 5,444 So Cal
Sinitro
So Cal
Thanks.
A couple of suggestions.. Check out.. www.Classicindustries.com Search out: 1. #MB15106 Mounting plate precut for a single din CD/AM/FM head unit, bolts rite in 2. #MB2098 Dual 3.5" spkrs and mounting plate 3. #MB2099 Like MB2098 but uses the better quality Kenwood speakers
I originally made my own front plate and speaker adapter for my RoadRunner, but now these are mass produced. Put ur 6x9"s in the rear tray and either #2 or #3 and U will have a solid, quality system. Also I put an iPod in the glove box..
Note that I do custom audio installs for different show cars (SEMA, CES), and can advise further if U need more support.
I hope that helps U.
Just my $0.05...
[Re: Sinitro]
#1597427
03/23/14 07:06 PM
03/23/14 07:06 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Thanks.
Just my $0.05...
the 'cage' will hold it in and get a back brace for the rear of the unit. the only issue and it's a silght issue is getting the unit level enough so the cd has clearance under the heater controls. i of course assumed this was a 68-70 RR because they are of course the coolest........
[Re: mikemee1331]
#1597428
03/23/14 07:22 PM
03/23/14 07:22 PM
Posts: 5,444 So Cal
Sinitro
So Cal
Thanks.
Just my $0.05...
Note that 68/69 are the same, 70 is different since the 70 RoadRunner has the ralley dash so the radio mounting plate is different. For a 70 RR we have used a radio delete repro plate and cut the DIN opening with a Dremel and carbide wheel. Regarding the back radio chassis support, no biggee the factory has a slotted bracket for the OE radio. Just make a short bracket and it drops rite in..
12V hookup is EZ as the fuse block is rite there by the glove box. Just unscrew and flip it over and use a 0.25" female tab connector on a switched terminal..
Just my $0.05...
[Re: Sinitro]
#1597429
03/23/14 07:33 PM
03/23/14 07:33 PM
mikemee1331
bethlehem pa
Thanks.
Just my $0.05...
Just my $0.05...
my " " was meant to be a " " and i didn't know that about 70's
[Re: mikemee1331]
#1597430
03/23/14 08:46 PM
03/23/14 08:46 PM
Posts: 1,032 Ohio
dobie
Ohio
Thanks for the help guys. I already have the face plate listed. I'll look into the front speakers. I wasn't planning on putting them in, but maybe its not a bad idea.
I'll just have to try to figure out the mounting bracket.
383 4 speed
[Re: dobie]
#1597431
03/23/14 08:51 PM
03/23/14 08:51 PM
mikemee1331
bethlehem pa
if there is a speaker already there you can use the mounting frame that holds the speaker in or look in the 'New Products' section. member 74dart (?) sells a bracket he makes.
[Re: mikemee1331]
#1597432
03/23/14 09:01 PM
03/23/14 09:01 PM
Posts: 1,032 Ohio
dobie
Ohio
No, there's no speakers in the car at all, currently.
383 4 speed
[Re: dobie]
#1597433
03/23/14 09:57 PM
03/23/14 09:57 PM
Posts: 1,032 Ohio
dobie
Ohio
So I just checked what I have in regards to the faceplate. I bought part number MP5550 from Year One several years ago. Unfortunately its no longer listed on their web site. Looking at the pictures however, it looks identical to the Classic Industries part listed above. Any experience with this older Year One part?
I just purchased #3 on the above list. May as well have something up front too, eh?
Oh, and yes, my car is a '68RR.
383 4 speed
[Re: dobie]
#1597434
03/23/14 11:34 PM
03/23/14 11:34 PM
Posts: 5,105 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
As far as the dash goes my Kenwood is installed in a 70 which as previously stated is different than the 68-9 models. Everything is typically the same with the exception of the finishes on the face plates. Mine had the stock pebble finish on everything. I removed those and fabricated all of those panels from aluminum. The cage installed into the aluminum and then I fabricated a bracket on the passenger side at the back of the radio to hold everything in. I did lower the opening in the aluminum a small amount to allow enough room for the radio face plate to flip open. I covered everything with a carbon fiber vinyl when finished.
...FAFO...
[Re: skicker]
#1597436
03/24/14 12:53 AM
03/24/14 12:53 AM
Posts: 5,444 So Cal
Sinitro
So Cal
Lets be kleer.. A 70 Satellite has the same dash and radio plate as a 68/69 RoadRunner. However... a 70 RoadRunner has a ralley dash like the 68/69/70 Charger and 68/69/70 Super Bee. So the radio mounting plates for a 68/69 RoadRunner are quite different in size/fit/finish than a 70 RoadRunner. Also some ralley dashes had a wood grain finish, I think the GTX did...
Just my $0.05...
[Re: Sinitro]
#1597437
03/24/14 01:00 AM
03/24/14 01:00 AM
skicker
"The Champ"
"The Champ"
Western Md.
Sorry Sinitro...mine was in a 70 Satellite. Non Rallye dash..
...FAFO...
[Re: dobie]
#1597439
03/24/14 10:19 AM
03/24/14 10:19 AM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
I mounted mine under the dash. I bought a mounting kit from best buy. I like it there and the stereo has a remote I use. Has bluetooth as well. Use front speakers if you have any kind of loud exhaust. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
[Re: dobie]
#1597440
03/24/14 11:21 AM
03/24/14 11:21 AM
mikemee1331
bethlehem pa
i have no experience with that faceplate or the under dash speaker system. i made my own faceplate with a dremel and some blank stock i had from some installation kit on a different car. and like i said, i made my own speaker bracket from the mounting plate of my original speaker. sorry.
