Re: 1985 dodge half ton rear end, LCA, steering wheel, ?'s
[Re: 98RAM1500]
#1597296
03/23/14 05:39 PM
03/23/14 05:39 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
yes the Tuff wheel with adapter will work on your non tilt column
sway bars are hard to find on the D series trucks some had them some didn't bout like a 70/30 chance
Not too hard to find pm when you can't find one then you will have found a few or more if I run out I have 5 P N Ps close to me
[Re: BulletBob]
#1597297
03/23/14 06:31 PM
03/23/14 06:31 PM
Posts: 1,176 Crockett ,TX
98RAM1500
Crockett ,TX
Well around here where I live (deep east Texas) which I should have put , but I have only seen 3 out of 50 or more D series trucks i've looked at over the years one off a 79 lil red, 78 lil red parts trucks I had one time and a 89 D150 parts truck that I currently have, but its on my 84 D150 project with the steering brace now
[Re: C_stripes]
#1597298
03/23/14 06:45 PM
03/23/14 06:45 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
I have a 1985 dodge ram with the 9.25 12 bolt rear end and 5 on 5.5 bolt circle. I have been looking for a sure grip unit for it and found a lot on eBay, however they are not very descriptive. I am wondering what spline my rear end should be and what years of sure grip unit will work?
There was a c-clip change around '85. That will be your determining factor on what suregrip units will work and what wont.
I asked this question to Dr Diff (Cass) and here was his response:
I don't know the dimensions, but in 1985, the thickness of the C-clips and the depth of the groove in the axles increased. I would stick the axles and C-clips into the carrier and check the fit.
So assuming your '85 has the newer parts, I believe '85-up should fit.
Spline count was unchanged as far as I remember on all 9 1/4's.
Outcast Dodge guy.
[Re: 135sohc]
#1597300
03/24/14 10:32 AM
03/24/14 10:32 AM
Posts: 15,487 Florida
scratchnfotraction
for the rear you flip the shackle using a front spring hanger on the rear then flop the axle on top of the springs,use car shock plates-ubolts. or use the drop shackles on the rear, I just got a set at the parts store for 43$ and they worked fine on my 85 stepside. I built and added traction bars on top of the leafs to the front hanger. so now I have the 88 440 truck with a flip flop and the 85 stepside with drop shackles. both sit about the same the way I likes them. look for a steering box/frame support bracket if yours does not have one when you add the sway bar. IIRC the stock d-150 sway bar will not work with the pocketed lower control arms...I think you use a 1 ton bar.
