2001 off Road Tire Size? #1597074
03/23/14 01:48 AM
03/23/14 01:48 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
What size are you guys running? It is time time and I would like to run some 285 70 17?
Re: 2001 off Road Tire Size? [Re: sthemi] #1597075
03/23/14 01:55 AM
03/23/14 01:55 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Wife has 285/75-16s on her 2001 Ram 1500. Slight rubbing when turing in/out of a griveway or approuch and only driver side. It makes contact with the back of the inner fender in front. We also run a 16x8 Rim.
https://www.treadwright.com/c-22-285-70r17.aspx
Re: 2001 off Road Tire Size? [Re: 76dodgeboy] #1597076
03/23/14 02:13 AM
03/23/14 02:13 AM
Waynesboro PA 17268
RODHALL Offline
RODHALL  Offline
Waynesboro PA 17268
2000 we had 285 70 17 slight rub at full lock.. no other issues..
Re: 2001 off Road Tire Size? [Re: RODHALL] #1597077
03/23/14 04:17 AM
03/23/14 04:17 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks,
Looks like I am spending some $$$ tomorrow..
Probably going to get BFG all terrain...
Re: 2001 off Road Tire Size? [Re: sthemi] #1597078
03/23/14 10:07 AM
03/23/14 10:07 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I put 33x12.50 Dick Cepek's on mine...
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 2001 off Road Tire Size? [Re: sthemi] #1597079
03/23/14 01:35 PM
03/23/14 01:35 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
No sweat running 285 70 17's on your Off-Road, Greg, did it on mine. They work really well with our 4.10's and I'm out 5% on the odometer.
The added lift from the factory helps for clearance on the front, I just had to trim my front flaps a little.
Also, I highly recommend these Michelin LTX AT2's: they are the narrowest 285 you can get, they are very quiet on the highway and the mileage is unreal. I'm over 120,000 miles on these and am just about hitting the wear bars. I'll easily get another 10 or 20 out of them. You get what you pay for though, they don't give them away.
Mo' Farts
Moderated by "tbagger".
Re: 2001 off Road Tire Size? [Re: Grizzly] #1597080
03/23/14 10:56 PM
03/23/14 10:56 PM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks for the replies,
It made buying the larger tires a bunch better.., since there are no returns..
I went with the BFGs 285s .. they had to order them, I will post pics when they are on...
My Goodyear Wranglers (in pic) went 66K...
Re: 2001 off Road Tire Size? [Re: sthemi] #1597081
03/24/14 03:36 AM
03/24/14 03:36 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Yeah, I got 63 out of mine before the typical goodyear BS set in: cupping and out of balance. That's a goodyear for you.
Funny, never even did a wheel alignment and threw new Michelins on and they are wearing perfect............right to the bitter end. Notice also there's no weights needed: they balanced out perfect with just a few grams on the inside of the rim.
Re: 2001 off Road Tire Size? [Re: sthemi] #1597082
04/06/14 01:21 AM
04/06/14 01:21 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Finally have the tires installed, they are really nice, the ride and handling are so much better..
No fitment problems at all, no rubbing.
Thanks for everyone's help.. here are a couple of phots...
Re: 2001 off Road Tire Size? [Re: sthemi] #1597083
04/06/14 01:22 AM
04/06/14 01:22 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
another
Re: 2001 off Road Tire Size? [Re: sthemi] #1597084
04/06/14 01:49 AM
04/06/14 01:49 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I kill a lot of tires at work and am not a fan of the Dick Cepek's or BFG A/T's. We have had the best luck with Goodyear and even better luck with Toyo's.
My truck tips the scales at 8400 with me in it so YMMV.
