A-body stock X member with a glide #1597007
03/22/14 11:35 PM
03/22/14 11:35 PM
canaan ct usa
moparclown Offline OP
canaan ct usa
Need some Ideas on modifying a stock style crossmember to fit a glide in an A-body.
Thanks for any help
Doug
Re: A-body stock X member with a glide [Re: moparclown] #1597008
03/23/14 12:13 AM
03/23/14 12:13 AM
Smithfield, Rhode Island
Mulehead Offline
Mulehead  Offline
Ain't nuthin like a HEMI !
Re: A-body stock X member with a glide [Re: Mulehead] #1597009
03/23/14 12:32 PM
03/23/14 12:32 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I used a simple piece of angle iron bolted to the front of the crossmember. I put it on a little low so I have to use 1/2" spacer between the trans and mount. Mine trans is mounted solid and has been for the last 18 yrs. Never a problem.
Re: A-body stock X member with a glide [Re: Mulehead] #1597010
03/23/14 01:13 PM
03/23/14 01:13 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
Mine is the same on my Duster.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
