Re: Stromberg Accellerator Pump
[Re: Andrewh]
#159703
12/02/08 11:38 AM
12/02/08 11:38 AM
Posts: 90 Laurens, SC
Radio Joe
Laurens, SC
Thanks Andrew. That makes sense. I got some gas running through it and it seems to squirt gas when I hit the throttle so I guess its good. Another question- Is the choke supposed to open all the way once the engien starts running? as soon as a vacuum is pulling on the engine the little vacuum choke pulls open all the way. Is that normal? I have a bunch of problems to work through right now- It appears that all the gas in the carb disappears overnight and the lines are empty. so in the morning it doesnt want to start- kills the battery trying to pump gas to the carb. Its a new fuel pump last year but the car has sat. I may upgrade to electric but that doesnt explain where the gas inside the carb went... There should be enough left in there to start the car in the morning atleast...
[Re: Radio Joe]
#159704
12/02/08 02:43 PM
12/02/08 02:43 PM
Andrewh
no generally it doesn't open as soon as you touch the throttle. sounds like the spring in the intake is bad, or you put the linkage on wrong.
It isn't hot enough or else I would say yes, that is pretty normal, that by the next morning, the carb is dry. Not the lines though. In the winter, I normally have to leave it a week before I dry out the carb. Are you sure that there isn't a leak somewhere? At the feed line would be my bet. When you shut off the engine, feel there and see if it is wet. Might be too hot for it to collect, or it runs off somewhere.
Worked on a few poly's and even have one forsale I plan on parting out soon, if you need something. Not too bad to work on except I hate the mech lifters.
[Re: Andrewh]
#159707
12/03/08 01:10 PM
12/03/08 01:10 PM
Radio Joe
Laurens, SC
Thanks again Andrew. Yeah I litly sanded the mating surfaces and they are VERY bad- you can see its not completely flat but i dont want to file it flat- I may also use some sealant. Thanks again for you help and advice- Money is tight right now and this is a toy so I am going to keep at it. for now
