1974 Scanp master cylinder #1596892
03/22/14 07:29 PM
03/22/14 07:29 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
I need a master cylinder for my '74 scamp. it a manual brakes with front disk and rear drum. Most places I look have different bore sizes. What is correct?
Re: 1974 Scanp master cylinder [Re: mopfried] #1596893
03/22/14 11:00 PM
03/22/14 11:00 PM
I have (had till it was hit) 74 A manual discs/10" drums (same as you/& 7&1/4 I'm assuming) in a 65 dart with the 1&1/8 alum M/C & it brakes flawless tho that is reportedly too large of a bore dia & others have reported way too much leg effort needed with that dia but it has worked for me (& I ain't that strong). Here's a BTT for ya since you ain't getting no love on this request.
Re: 1974 Scanp master cylinder [Re: mopfried] #1596894
03/22/14 11:01 PM
03/22/14 11:01 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
As far as I know should only be maybe 2.One for drum/disc and one for drum/drum.Rocky
Chrysler Firepower
Re: 1974 Scanp master cylinder [Re: mopfried] #1596895
03/23/14 12:26 AM
03/23/14 12:26 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Chrysler '74 parts book shows part# 3580146 for manual disc/drum but no size is shown. Rockauto.com shows several brands and the size as 1-1/32". The Chrysler part# crosses to a Dorman# that is one of numbers Rockauto shows as 1-1/32. From this info I would say 1-1/32 is the correct size.
Re: 1974 Scanp master cylinder [Re: moparfan53] #1596896
03/23/14 09:35 AM
03/23/14 09:35 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If you have the old master just pull the guts and see what size it is.They are all marked on the rubber cup.Exchange they dont care if its apart or not.Rocky
Chrysler Firepower
Re: 1974 Scanp master cylinder [Re: therocks] #1596897
03/23/14 11:12 AM
03/23/14 11:12 AM
moparx Offline
moparx  Offline
my wagner master catalog says 1 1/32" for manual brakes {F83578 for drum and F88787 for disc] and 15/16" for power [F80266 disc/no drum brake master listed]. this is 74/76 applications. hope this helps.
Re: 1974 Scanp master cylinder [Re: moparx] #1596898
03/23/14 06:15 PM
03/23/14 06:15 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
I pulled the master cyl off and it measures 1.060 right at the opening. I didnt remove the snap ring or the plunger so Im gonna assume it is the 1-1/32 bore. It originaly came with a 8-1/4 rear, now it has a 8-3/4. It stopped fine just they cylined leaked out all the fluid over the winter.. Ran down the firewall and messed up my pretty yellow paint.
